Thread: Hooked up a Fuel Pressure Sender (with pics)
Results 1 to 7 of 7
  1. #1 Hooked up a Fuel Pressure Sender (with pics)
    SE Level Member BlackGS's Avatar
    Central Jersey
    I finally got around to hooking up my VEI Fuel Pressure sending unit. I have the ZZP fuel logs, but this could also be hooked up to stock rails if you get an adapter for the front schrader valve. I wanted to hook this sender up and get the signal back to my HP Tuners scan, although it could also be sent back to a gauge.
    The really cool thing I found is that the signal can be routed through the EGR wiring (my EGR was removed some time ago because of the intercooler). Everything is right there - power, ground, and signal wire. The VEI sender requires 5v power, and that is found on the EGR connection (gray wire). Ground is the black wire, and signal return is the brown wire. I didn't have to route any wires through the firewall.
    In HPT, I just added a custom PID and included the EGR signal volts * 20. Perfect Fuel Pressure readings!
    Here's where I bought the sender:
    vGauges
    I also picked up the adapter block, and a 1/8" to 1/4" adapter. The gauge is from Summit.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  2. #2 Re: Hooked up a Fuel Pressure Sender (with pics)
    Barksdale AFB, LA
    Very interesting. I love how you connected it through the OBD2 system.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Hooked up a Fuel Pressure Sender (with pics)
    Central Jersey
    Quote Originally Posted by Sabrewings View Post
    I couldn't believe the three wires I needed were literally inches away. Stuff like that never happens.
  4. #4 Re: Hooked up a Fuel Pressure Sender (with pics)
    TDCRacing
    Guest
    Nice to have you here. And very good info. Will be doing this soon.
  5. #5 Re: Hooked up a Fuel Pressure Sender (with pics)
    i think the only way a fuel pressure gauge is useful is if its in the cabin so you can watch it.
  6. #6 Re: Hooked up a Fuel Pressure Sender (with pics)
    Central Jersey
    You need it in the engine for an adjustable FPR. Doesn't do much for WOT though.
  7. #7 Re: Hooked up a Fuel Pressure Sender (with pics)
    TDCRacing
    Guest
    The scanner is in the cabin.
  1. are fuel sender units compatible with other brand gauges?
    By fst in forum General Tech Discussion
    Last Post: 10-03-2008, 04:42 PM
  2. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  3. fuel pressure question
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 11:35 AM
  4. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
