Thread: odd temp level... I think...
Results 1 to 13 of 13
  1. #1 odd temp level... I think...
    SE Level Member schollianmj's Avatar
    Dec 2012
    Virginia
    ok, just picked up my 2000 GTP tonight, and noticed that after driving for 60 miles this is all the higher the temp gauge would go. is this normal? bad sensor? bad T-stat? I plan on flushing the crap outta the rad and system but was wondering what the normal place on the gauge for the needle.
  2. #2 Re: odd temp level... I think...
    Normal
  3. #3 Re: odd temp level... I think...
    The Boss Iceman6669's Avatar
    Jun 2011
    my 97 starts at 100* but that is about where mine runs also
    2011 F-150 Yote powered
  4. #4 Re: odd temp level... I think...
    mine starts at 100 as well but that's just because i'm awesome
  5. #5 Re: odd temp level... I think...
    Jun 2011
    REALLY???? did you replace the cluster? I thought only 97s did that....
  6. #6 Re: odd temp level... I think...
    Mine is an early 98
  7. #7 Re: odd temp level... I think...
    I'd guess its at 185-190. Mine runs at the frist big dash and thats 195-200 and stay there.
    A rad flush and new thermostat (with bleeding the air out) will do the car good and you'll be golden.
  8. #8 Re: odd temp level... I think...
    Dec 2012
    Virginia
    cool. it just looked low to me.. Im used to the needles being close to the middle. Definitely planning a flush soon. there are other issues with my radiator that i mentioned in my Noob thread..
  9. #9 Re: odd temp level... I think...
    Apr 2011
    Elk Rapids, Michigan
    That's where mine runs. I have a 180 degree thermostat in. It was about 4 divisions higher when I had the 195 in.
  10. #10 Re: odd temp level... I think...
    Dec 2012
    Virginia
    195 is stock for these cars right? Im assuming the 180 helps avoid Knock? On a stock car is there any real reason to go to a 180? Im thinking getting a new T-Stat tomorrow and a new cap for the Rad. Just checking what I should look at gettig.
  11. #11 Re: odd temp level... I think...
    Apr 2011
    I put the 180 in for summer driving. It keeps things a little cooler in stop and go driving. I also have an oversized ZZP radiator to put in before next summer.
  12. #12 Re: odd temp level... I think...
    Keep the stock 195, its what best for the car.
    In reality, the temp difference of 10-12ยบ does hardly anything for us, everything heatsoaks. But thats another topic.
  13. #13 Re: odd temp level... I think...
    Dec 2012
    Virginia
    Thats what I figured FFDP. good to hear my thoughts confirmed. Thanks.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Intake temp vs coolant temp.
    By chicagochuck in forum General Tech Discussion
    Last Post: 09-30-2012, 08:44 PM
  3. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  4. Temp gauge, PRND321 Lights, Oil Level Switch
    By ktmccrary in forum General Tech Discussion
    Last Post: 12-10-2010, 02:54 PM
  5. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
