Thread: loss of power after burnout (on a swap)
Results 1 to 20 of 24
  1. #1 loss of power after burnout (on a swap)
    miami fla.
    Ok short story made long.
    Swapped a 99 gtp engine, tranny n ecu into my 90 vw gti.
    Dont bother asking why. Its been asked before. Something to do
    With too much time on my hands, boredom and some sort of bet
    I won but never got paid on.
    Ok heres the problem and I dont know where to look....
    Put it all together, checked rechecked n did more checking.
    Car turns on, on the first try, idles like (well) a gtp (lol) .. no
    Misses no sputters nothing that would indicate a problem.
    Put e-brakes on, put her in "D" and mashed the pedal to the
    floorboard.. I was rewarded with glorious whining n testosterone
    Producing tire smoke, from both tires- weird I thought it was one
    wheel wonder. I digress. All my friends are jumping for joy and
    Clapping their hands together as if they had just witnessed the
    Miracle of a lifetime..
    I let it idle for a bit. Check fans fluids and all other nick nacks.
    Everything is five by five.. let her cool off n more friends show up.
    Im starting to think maybe I dhould be charging admission at this point.
    They all want to see hitlers foot locker burn rubber one more time.
    I say lets do this! Everything as before car gets about 6 psi of boost on guage
    But no shredding of tires. Front tires push car forward. Put water under tires.
    Same thing, car wont burn out for its life. It feels like a dog on the streets.
    My brothers gtp will smoke the tires from a stop sign gor quite some distance
    Ill be lucky if I can do it for 4 inches.
    All fluids are ok. Tranny shifts fine. Just no power. Boost holds at 6-7 psi.
    Could it be knock sensor pulling timing out? Tranny? Converter took a dump?
    I had computer reflashed after problem happened but still its there.
    Im leaning more towards the converter, but would like some opinions
    Before I tear into engine n tranny.
    Mods: stock blower /pulley. Stock injectors, fuel cell, -8 feed -6 return,
    Walbro 255 pump, 4' cold air kit with cone filter (new). 3' exhaust front
    To back with resonator and dynomax mufler. Rear o2 disabled on new tune
    And thats more or less it. This thing should roast the tires on such a light car.
  2. #2 Re: loss of power after burnout (on a swap)
    new britain, ct
    great swap!
    6 psi doesnt sound like normal boost. normal should be at around 8-9 psi. maybe its a big vacuum leak? have you done the LIM gasket before?
    07 Black GXP.
  3. #3 Re: loss of power after burnout (on a swap)
    8-9 PSI on stock pulley?
    Maybe in the cold...maybe.
    Most stock cars with factory exhaust pull about 5-7 psi at the shift....the restrictive part is in the manifolds/DP...6 psi is probably about right.
    I'd do a pan drop and see what's going on, get a shift kit from Intense-Racing if you haven't cracked into the transmission yet...as I'd also recommend checking the cat if you haven't...could be clogged...could also be what you thought of the converter dying out on you as well...
    Stock ecu has a few things like diff/trans abuse protection.
  5. #5 Re: loss of power after burnout (on a swap)
    I can't believe the first thing you did after getting it together is a burnout. Was the motor warm when you did it? Stock the knock sensors don't turn on until 160*
  6. #6 Re: loss of power after burnout (on a swap)
    May 2008
    Schuyler, NE
    Do you have a scanner?
  7. #7 Re: loss of power after burnout (on a swap)
    miami fla.
    No scanner, car was about 160 when burnout was done. No cats on car. Complete 3 inch exhaust from manifold to tail pipe.
    Whole ecm was flashed, fans now come on sooner tranny permanently left on high performance mode. Still does it.
    Tranny shifts fine while while driving.. doesnt flare under acceleration.. its like im missing a lot of horses somewhere..
    Lim gasket is fine,exchanged it 2 days after getting motor. No other mods made to engine.. all hoses prone to cracking
    Have been changed. Like previously stated, idles n runs like a champ. But feels like a na 6cyl to me.
  8. #8 Re: loss of power after burnout (on a swap)
    New V6's make 50+ more HP than the L67...news?
  9. #9 Re: loss of power after burnout (on a swap)
    miami fla.
    Quote Originally Posted by blueguy91 View Post
    Yeah... and my turbo drag stang makes about 900+ more hp than the new v6.
    Thanks for your information, but knowing that doesn't solve my roblem. Thanks
  10. #10 Re: loss of power after burnout (on a swap)
    SWPA
    Do a compression check.
  11. #11 Re: loss of power after burnout (on a swap)
    miami fla.
    I did a leakdown and compression test. All good.
  12. #12 Re: loss of power after burnout (on a swap)
    What kind of vacuum are you pulling at warm idle? Does it run fine if you stomp the gas while driving?
  13. #13 Re: loss of power after burnout (on a swap)
    miami fla.
    Sorry boost gague doesnt have vacum. Its a blower Guage from my old race car. Car accelerates just fine and idles awsome. No stumbles or hessitation of any kind. Just no power. My brothers car , 98 gtp roasts the tires at will. Mine cant drive itself out of a wet paper bag.
  14. #14 Re: loss of power after burnout (on a swap)
    It's probably the torque management. You could tune it out
  15. #15 Re: loss of power after burnout (on a swap)
    Pull the upper o2 sensor before the cat and give it a whirl.
    It will sound like a tractor, but if the pick up and go is faster you may have found the problem.
  16. #16 Re: loss of power after burnout (on a swap)
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    he has no cats.Get a scanner from autozone or something.A scanner will tell you alot.You will probly need a scanner in the future anyways if you have anything newer than 1990.lol
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  17. #17 Re: loss of power after burnout (on a swap)
    miami fla.
    Thanks for the help guys. I have a scanner. The only code I would get would be the rear o2 sensor, because I had it disconnected.
    They tuned that out. The tune I got from zzp is what they call a dunebuggy tune. Basicaly everything that is not needed is turned off
    And what not. The problem was there before the tune and didnt change a bit after.
    I have no cats!
  18. #18 Re: loss of power after burnout (on a swap)
    Feb 2009
    flintnasty MI
    tune is probably fine.
    I would imagine you have misfires... plugs, wires, too much fuel for some reasons.. check in that order.
  19. #19 Re: loss of power after burnout (on a swap)
    miami fla.
    New taylor wires, iridium plugs. Dont have a fuel pressure guage on it, but I dont smell fuel at idle. It idles and accelerates good. Just no power.
  20. #20 Re: loss of power after burnout (on a swap)
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    how does it accelerate good with no power? gonna need to hook up to a scan tool to see what is going on.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  1. Need Help! Loss of Power
    By 01GTLAK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2012, 03:41 PM
  2. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  3. power loss
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-15-2010, 02:57 PM
  4. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  5. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
