Thread: 2000 gtp oil leak please help!!!!!
Results 1 to 19 of 19
  1. #1 2000 gtp oil leak please help!!!!!
    May 2012
    This is my first car and I have a slight oil leak and I am just worried about the cost of repair I'm thinking its the upper intake manifold gasket but what scares me is that the other day I watched as it ran and I seen slight smoke from the rear of the engine like near the firewall, but the oil thats actually making it to the drive way is near the front and I could see towards the front where it was leaking after running for a while so maybe I have 2 leaks? its a very small leak and I'm hoping it hasn't caused too much damage yet because I havent found any coolant/oil mixture yet but I am just afraid what I will find one I take the manifold off plus, at this point I don't even know if thats the cause it's just making me worry because this was my dream car the 2000 gtp with the bronze metalic and tan interior with low miles but now I think I know why I got such a good deal so what am I looking at labor wise cost wise and any other problems that could happen if I don't correct them before that point
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Just replace the LIM gasket and your Valve cover gaskets. No more damage can be done than what's already happening.
  3. #3 Re: 2000 gtp oil leak please help!!!!!
    valve cover leaks can travel around the oil pan no problem. get new vc gaskets, then clean the engine, and watch for the leak to pop up again.
    you can also take a look at the oil pressure sensor, its located on the housing where the oil filter is screwed on. that sensor likes to leak, it leaks out the plug, and can be a bad leak, they start off as a small leak, and then get worst over time. run the engine wile looking at it, see if it dry, if its wet looking, the plug that is, its leaking. good thing, they cost 12 bucks.
    lim gasket should be done if you have the plastic gasket still. look where the lower intake meets the head, for either black ( plastic ) or silver (metal) gaskets. metal you are good to go, black, you should plan on changing them.
    also check the lim bolt valleys. are they dry? or wet with puddles over the bolts? if its wet the lim for sure needs to be done.
  4. #4 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Thank you I'll definately try I I havent yet master mechanics just simple stuff...now would it be pricey to do the valve cover gaskets and lim gasket
  5. #5 Re: 2000 gtp oil leak please help!!!!!
    Where in Jersey are you? I know a couple of guys in that area that I'd recommend and would not charge a billion.
    Nighthwk12 aka Justin is one
    Me..I'm kinda nearby depending on how you look at things
    Etc etc.. It's early
  6. #6 Re: 2000 gtp oil leak please help!!!!!
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Let's do it to it. My zip is 07748. Doing the valve covers and lim gasket is a breeze and a good point to learn your car, engine, and how to turn a wrench. The parts aren't that pricey either.
    97 Bonneville SE Not so much a 97 anymore
  7. #7 Re: 2000 gtp oil leak please help!!!!!
    I didn't even pm or text him. I swear people know when I type their names.
  8. #8 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Thank you everyone for the help!!!!!!It's really appreciated this was my dream car and I was so scared it might be something big I was thinking about trading it in for a 1999 pontiac bonneville ssei..........Don't think I will now
  9. #9 Re: 2000 gtp oil leak please help!!!!!
    Hold up ace.. The GP is a POS in my eyes. You happen to speak the best words possible. Bville SSEi and 99 is a damn good year.
    Go sit in that Bonne and adjust the seat,
    the Bonnie is nearly as moddable as a GP. Easier in most cases. Add $80 drag bags to the rear and in conjunction with the auto leveling, you won't have weight transfer issues like the GP's. Lemme show you a few things
    Bonne makes it so nice to IC
    Car was nearly made for an FWI
    Intercooling..piece of cake. No worries of ever hitting things with the hood. Tons of room for a huge front mount
    Want and electric water pump or IC pump, heck..you can put the fuses and relays right in the factory relay center
  10. #10 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    I know just right now I cant find one in my area with low miles and it has to be a ssei so and plus I would have to trade mine in so I would need something comparible
  11. #11 Re: 2000 gtp oil leak please help!!!!!
    Ei is not comparable to a GP, it's far superior
  12. #12 Re: 2000 gtp oil leak please help!!!!!
    Mar 2012
    NC
    The SSEI is more comfy...and I <3 my GP.
  13. #13 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Plus I will miss my heated seat lol but i feel the ssei is better looking and better built so Im trying to ideally find a white 99 ssei w tan interior and the chrome rims with low miles....,so I know Im asking for alot but wen n if I find it I will just get it as a second car or trade my gtp
  14. #14 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Same here I love both cars equally they each have their perks and downfalls
  15. #15 Re: 2000 gtp oil leak please help!!!!!
    Mar 2012
    NC
    Ok, now back to this GTP...let's get it fixed!
  16. #16 Re: 2000 gtp oil leak please help!!!!!
    Yep.. another guy in the area that sometimes does work is Scottydoggs... good guy.
  17. #17 Re: 2000 gtp oil leak please help!!!!!
    Nov 2009
    Central Jersey
    Quote Originally Posted by firstgtp View Post
    Bonne's also came with heated seats.
  18. #18 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Once I put it on the road I am going to have it looked over and just keep an eye on it if it gets really bad I will bite the bullet try to get some money together and try to get it to a nearby guy, I don't think the 99 bonne's have heated seats
  19. #19 Re: 2000 gtp oil leak please help!!!!!
    May 2012
    Thanks everyone because at least I know what the problem probably is
  1. 2000 GT oil leak
    By Autoworks in forum General Tech Discussion
    Last Post: 03-12-2013, 01:34 AM
  2. Coolant leak behind power steering box - 2000 Grand Prix V8
    By wcoughlin in forum Introductions/Noob Questions
    Last Post: 10-09-2012, 08:46 PM
  3. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  4. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  5. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
