Thread: 1999 GTP temperature issue
Results 1 to 6 of 6
  1. #1 Re: 1999 GTP temperature issue
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    first off the gauge does lie to you they all do use a scanner device to read the actual temp, remember the tstat is 195* (factory) im not sure what your stock fan turn on speeds are though i lowered mine. bleed the air out of the system with the bleeder cap on top of the tstat housing the car can be level all the caps should be on. air in the system does cause it to run hotter then so that could just be your problem (i dont know if you know exactly how to bleed a car but the tstat has to be open and flowing before you can start bleeding)
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: 1999 GTP temperature issue
    Dec 2012
    Ohio
    Thanks I am bleeding it correctly with stat open. Seeing no air now at all. Is there a way to get the gage to read correctly? I used a scan tool and it is not overheating. Just read way to close to 260 for me and want to be able to depend on it in case something would go wrong in the cooling system.
  1. Temperature/AC issue
    By Mconner in forum General Tech Discussion
    Last Post: 06-16-2012, 11:09 AM
  2. Temperature is all over
    By aray590 in forum General Tech Discussion
    Last Post: 03-13-2012, 10:01 PM
  3. Help With Temperature Gauge issue!
    By gcschi22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2011, 10:55 AM
  4. High temperature
    By Haulero in forum General Tech Discussion
    Last Post: 08-15-2010, 05:49 PM
  5. Is this temperature normal?
    Last Post: 05-24-2010, 11:45 AM
