Thread: engine sputters under hard Accelleration
Results 1 to 6 of 6
  1. #1 engine sputters under hard Accelleration
    Dec 2012
    canada
    can someone please help me on this, i dont know where to look anymore.
    whenever i step on the fuel, under hard accelleration, my engine sputters and basically dies. zero power.
    we cant have a supercharged pontiac grand prix gtp (02) not pass a car on the highway now can we?
    i have replaced the air filter, plug wires, catalytic converter and full exhaust. there are no engine codes.
    it runs great unless i spool up that supercharger.
  2. #2 Re: engine sputters under hard Accelleration
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    u do the plugs mine did that i had a cracked plug
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: engine sputters under hard Accelleration
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Definetly needs new spark plugs
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  4. #4 Re: engine sputters under hard Accelleration
    what kind of plugs did you used, and was there a problem before the plug change?
  5. #5 Re: engine sputters under hard Accelleration
    Apr 2009
    Elkhart
    he says he changed the plug wires but no plugs i would go to plugs and look for the black crack LOL
  6. #6 Re: engine sputters under hard Accelleration
    Probably a vac leak.
    Bet on it.
  1. Car sputters when accelerating hard
    By joemama22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2015, 12:53 PM
  2. engine sputters under acceleration...
    By GTP2G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2012, 08:29 PM
  3. stalling under accelleration
    By kevs84s in forum General Tech Discussion
    Last Post: 11-11-2010, 11:50 PM
  4. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
  5. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
