Thread: How do i Adjust the butterfly after cleaning TB i have a high idle.
Results 1 to 4 of 4
  1. #1 How do i Adjust the butterfly after cleaning TB i have a high idle.
    Jan 2009
    Utica Missouri
    So a few weeks ago I took my throttle body apart to clean it, nothing wrong just wanted to clean it, Well now, it idles way to high, (some times 3k-5k rpm) like the butterfly is not closing 100 percent perfect. What gives? How do I adjust the butterfly so I can get it closed?.. If I get out and push the throttle closed it will idle right, but it feels like im Barely moving it. I have took the two screws out flipped the plate, turned the plate nothing gives.. I just can’t get it to close 100 percent.
    It Closed fine be for what did i do!?
  2. #2 Re: How do i Adjust the butterfly after cleaning TB i have a high idle.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    did you put a new tb gasket? vacuum leaks? hissing noises?
    did you mess with the idle screw your throttle cable rests on?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: How do i Adjust the butterfly after cleaning TB i have a high idle.
    Jan 2009
    Utica Missouri
    I figued it out and kind feel dumb cruise cable was out of its holder cusing it to hold the throttle in about 1/40th of an inch
  4. #4 Re: How do i Adjust the butterfly after cleaning TB i have a high idle.
    Nov 2012
    Madison
    good thing you got it ,that woulda made for a nasty crunch from park into reverse or drive, let alone some crazy driving
  1. High idle?
    By JESSEGOTTA GP GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 01:47 PM
  2. High idle but no code set
    By viv1610 in forum General Tech Discussion
    Last Post: 05-10-2011, 06:12 PM
  3. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  4. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
