Thread: Fuel injector help !!!!
Results 1 to 20 of 21
  1. #1 Fuel injector help !!!!
    SE Level Member GTPAIELLO's Avatar
    Aug 2012
    weymouth, ma
    Hi ! I'm kinda new to the forum and have got a lot of good info so far, so here's my issue . I have 60# injectors and need to add them to my hp tune . Pretend you are writing a write up for " injectors for dummies " lol ! I have no clue how to dial them in or adjust ect . Is there a easy way ? I need this done so I can start my base MAF tune . Thanks a lot !!
    2000 GTP - TURBO SETUP .
  2. #2 Re: Fuel injector help !!!!
    60lb. injectors...for what? lol.
  3. #3 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Oh crap lol my bad 2000 GTP
  4. #4 Re: Fuel injector help !!!!
    No I mean, why do you have 60lb. injectors...?
  5. #5 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Ported intake ,ported SC, lim, intercooler , smaller pulley , billet fuel rails, adj fuel pressure regulator
  6. #6 Re: Fuel injector help !!!!
    That's pretty damn vague.
    I ran stock injectors down to a 3.2" pulley.
    If you're on pump gas there is no need for 60's.
  7. #7 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Sorry man that I don't specifics it's my brothers car this is his account I'm just trying to help him get it going , he already has them they are in the car now I just need some help adjusting them , any help is greatly appreciated
  8. #8 Re: Fuel injector help !!!!
  9. #9 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Yeah the last two weeks I have been here.
  10. #10 Re: Fuel injector help !!!!
    Here ya go...gotta dig man...it's there.
    60lb injector tuning - HP Tuners Bulletin Board
    That's for pump gas as well.
  11. #11 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Ok mod list lol
    Current mods -zzp inlets and outlets ported sc. -ZZP ported lower intake -ZZP stage 2 tb and tb spacer. -cold air intake - tog
    headers and downpipe -ZZP fuel logs. -60 lb injector -180 stat -103 spark plugs - 10.5 mm wires - ZZP stage 2 intercooler. 3" pulley
  12. #12 Re: Fuel injector help !!!!
    Needs a MAF tune for that ported TB as well...if you didn't know that
  13. #13 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Thanks man I will check it ou
  14. #14 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Yeah def need to do that too heard from someone to do injectors first then go to the MAF
  15. #15 Re: Fuel injector help !!!!
    Do both, then upload at same time.
    I'd also pulley up...because if it starts knocking...a larger pulley is going to be way more forgiving.
    Hopefully you have a wideband as well.
  16. #16 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    Yeah I do have a wideband I'm installing this weekend . So just put the pulley on while tuning then swap back after ??
  17. #17 Re: Fuel injector help !!!!
    I mean, start tuning with a larger pulley and the wideband and work your way down.
  18. #18 Re: Fuel injector help !!!!
    Aug 2012
    weymouth, ma
    thanks for ur help man appreciate it
  19. #19 Re: Fuel injector help !!!!
    A third thread about the same thing that's been answered 5 times? Yeah..I'm locking this.. please continue in one of the other threads.
  20. #20 Re: Fuel injector help !!!!
    I was just about to say the same thing bill.
  1. Fuel Injector Cleaning
    By Burbman in forum General Tech Discussion
    Last Post: 12-04-2012, 11:58 AM
  2. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  3. prj fuel rainl/ injector help
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 02:55 PM
  4. fuel injector / pcm issues?
    By mastert429 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:43 AM
  5. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
