Thread: gen v vs. gen 3
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 gen v vs. gen 3
    antioch ill
    would i be better off taking my gen gettin it ported and run a 3.4 along with plog and tune. i already have a intake and plugs. or get a gen v and do the same support mods and what could i run then? would the cost outweigh the gains?
  2. #2 Re: gen v vs. gen 3
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Gen V is still better and more efficient than a ported Gen 3. Pulley size on Gen 3 to Gen V do differ . A Gen V with a 3.4 will require headers, colder plugs, CAI and Tune
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: gen v vs. gen 3
    antioch ill
    so will a gen 3. i guess what im saying is whats the lowest i can run on a gen v compared to gen 3 on just headers tune plugs and cai
  4. #4 Re: gen v vs. gen 3
    Jan 2009
    the lowest is 3.4 on a Gen V anything lower will require cam , inter cooler and other bigger mods which could be found on the safely mpdding thread posted by "blue"
  5. #5 Re: gen v vs. gen 3
    antioch ill
    and im guessing a 3.2 on a gen 3?
  6. #6 Re: gen v vs. gen 3
    Jan 2009
    that sounds about right
  7. #7 Re: gen v vs. gen 3
    antioch ill
    soo basically i couldd save money and just throw a 3.4 scan and make sure im not gettin a butt ton of kr and go to a 3.2 with the same support mods. i mean im not gonna cam or ic just bolt on stuff you know
  8. #8 Re: gen v vs. gen 3
    Jan 2009
    yes you could do that, I personally like the Gen V better (cooler engine bay and more"whine"). I have a ported gen 3 on my gtp right now (reptile ported) . I used to have a 05 CompG with the Gen V and all supporting mods with a 3.4 and I miss the cool engine bay and the "whine" from it.
  9. #9 Re: gen v vs. gen 3
    antioch ill
    is there really that big of a difference in whine ive been told by a few people now
  10. #10 Re: gen v vs. gen 3
    Jan 2009
    Huge difference, and the Gen 3 runs super hot you could barely touch it without getting burn where as the Gen V is cool all the time.
  11. #11 Re: gen v vs. gen 3
    antioch ill
    idk if its worth 200+ for the blower than $100 for the tb adapter along with a lim
  12. #12 Re: gen v vs. gen 3
    antioch ill
    would the gains be the same for a gen 3 3.4 and gen v 3.6 or would there be a advantage to the gen v due to it being more efficient
    More efficient = less heat and less potential knock.
    04 Comp G.
  14. #14 Re: gen v vs. gen 3
    Indianapolis
    Ummm headers, intake, colder plugs and tune would get you a 3.4 on a gen 3 and a 3.6 on a gen v
  15. #15 Re: gen v vs. gen 3
    Nov 2011
    NY
    Quote Originally Posted by 97gtpjoe View Post
    First time I can remember reading, seeing or hearing this anywhere... Just saying.
    Quote Originally Posted by coolone View Post
    Agreed
    04 Comp G.
  17. #17 Re: gen v vs. gen 3
    michigan
    Sub'd
  18. #18 Re: gen v vs. gen 3
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    a 3.2 with plog, intake, tune, plugs on a ported Gen 3?
    No, 3.4 at the lowest IMO.
    Get headers.
    3.4 = More boost but more heat OR
    3.5 = More timing, less heat but less boost.
    Pick your poison.
    And as for the Gen V, you could run a 3.6 on a Gen V and that would roughly equal a 3.4 on a Gen III but the Gen V will be more efficient. Gen V > Gen III
  19. #19 Re: gen v vs. gen 3
    antioch ill
    i feel headers would be hard to install. im probally wrong tho they just look really intimidating
  20. #20 Re: gen v vs. gen 3
    its 6 bolts per head, then break the bolts off the cat to res, and take the cross over off, the egr off, then re install the headers. cant be that hard at all.
    bills got a good how to listed.
gen
