Thread: Stroked GTX L67...
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Stroked GTX L67...
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Basically what i want to know is the good and the bads of a stroked L67 and what it actually does since i really dont know much about that. Reason as to why i asked is i bought a gtx which some of you may have seen already about 2-3 weeks ago and the guy claims it is stroked and wanted to learn as much as i can about that topic and to see and find out if it really is or not before i start putting money into something idk of how is built.
    Some vids that i have posted before..
    Gtx 2 - YouTube
    Pontiac gtx - YouTube
  2. #2 Re: Stroked GTX L67...
    Texas
    There is no way to tell if its stroked unless you tear the engine apart. Regardless, the engine sounds like its about to come apart.... In a bad way. What all is done to it? I see the nitrous or meth and it sounds like its cammmed or has a nasty vac leak.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Stroked GTX L67...
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    A stroke kit was made a long time ago. The balance was so off the shift points had to be lowered ha
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: Stroked GTX L67...
    First thing I'd do is research the car on the internet. If it's stroked, there is likely a large build thread on one of the many 3800 forums.
  5. #5 Re: Stroked GTX L67...
    Buena Park Ca
    In those videos yes it does sound bad but to me it's more of a lifter tick or pushrods something small not big at all.
    As far as the vacuum goes yes it's pretty bad on the video but that was when it had the codes I will uPload a vid of how it runs when i erased them and idled fine and sounded good besides the tick.
  6. #6 Re: Stroked GTX L67...
    Buena Park Ca
    I have tried already but found nothing to very little info and videos on stroker builds for our gp yet alone this GTX.
  7. #7 Re: Stroked GTX L67...
    Ohio
    Quote Originally Posted by GTP89 View Post
    ....or pushrods something small not big at all......
    pushrods aren't a big deal?
    sounds plausible.
  8. #8 Re: Stroked GTX L67...
    Swan Racing's domain/page is gone.
    Le fail.
    They were the only ones to make a worthwhile kit, it was just expensive as hell.
    Like slow said...only way you're going to really find out or not is to pull the engine and rip it apart and measure the cylinders wall to wall.
  9. #9 Re: Stroked GTX L67...
    GTP Level Member joe0813's Avatar
    Boston, MA
    sounds like you will be ripping the motor apart anyways with that awful tick.... you might want to get looking on that before something gets worse and leads to way bigger issues
  10. #10 Re: Stroked GTX L67...
    Buena Park Ca
    Quote Originally Posted by 99PGPGT View Post
    sounds plausible.
    It is but nothing bad like a rod gone bad or something that can be replaced pretty easy as long as nothing else went bad.
  11. #11 Re: Stroked GTX L67...
    *reasons to not buy modded car*
    Blown motor.
  12. #12 Re: Stroked GTX L67...
    Buena Park Ca
    Quote Originally Posted by blueguy91 View Post
    Le fail.
    Can i verify if it strokes by dropping the bottom oil pan and taking a look?
    According to the guy it has forged JE Pistons in it.
  13. #13 Re: Stroked GTX L67...
    I'd rather pull the motor than drop the pan with the motor in the car.
  14. #14 Re: Stroked GTX L67...
    Buena Park Ca
    Quote Originally Posted by joe0813 View Post
    I am just don't know if I should replace the lifters as of now as well as pushrods.
  15. #15 Re: Stroked GTX L67...
    Buena Park Ca
    That will be done but I just don't wanna pull the heads and get down that far in and replace all gaskets and such again I don't mind tearing everything else down just the heads I don't want lol
  16. #16 Re: Stroked GTX L67...
    Buena Park Ca
    Blown motor.
    Couldn't pass up the deal and it runs with a tick of course.
    But over all couldn't let it go to some guy that knew nothing about these cars.
  17. #17 Re: Stroked GTX L67...
    If you're going to do it...just get it done.
    Not like the 3800 is an expensive motor by ANY means. You'd be looking at a few hundred bucks.
  18. #18 Re: Stroked GTX L67...
    Buena Park Ca
    I am that's the idea but want to do it right since idk what to watch out for or look for if it really is stroked.
  19. #19 Re: Stroked GTX L67...
    Boston, MA
    I wouldnt replace anything until you know for sure what the tick is.
  20. #20 Re: Stroked GTX L67...
    I already told you.
    Measure cylinder bore.
    After you tear it apart.
