Thread: need a little help
Results 1 to 8 of 8
  1. #1 Re: need a little help
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    yea they are the stock wires i tried pulling on the heat shield but still didn't have any luck yet, also i heat shield slides up and down so i know thats not the problem do you think that it is possible that some how the wire and plug could have fused together (crazy thought)
    alright i finally got it off the heat shield doesn't look as pretty now, an i don't really approve this method but o well i had to do what i had to do
    1. put vice grips on the heat shield not to tight but not to loose
    2. put a piece of pipe over part of the handle a pry
