Thread: L32 power cabibilities on stock cam??
Results 1 to 15 of 15
  1. #1 L32 power cabibilities on stock cam??
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    Looking at doing a small build on my wifes 04 compg . Its still our DD/Family car and dont really wanna do a cam right now. so far the build plan is as follows
    HS 1.9 rr
    SD headers
    42.5# injectors
    ZZP stage 2 intercooler
    HPtuners
    CAI
    3.0 pulley
    and all the supporting mods (180 t stat, 104's, 90lb springs, ect)
    now question is, being that the cam is the limiting factor, how much power can we make with this set-up? I am fully capable of doing a Port and polish on both the LIM and heads if it would help. I dont know if digging in that deep and P&P then heads/LIM would be worth it on a stock cam car? maybe good for a slightly smaller pulley (2.7ish)? dont ask why i dont want to cam the car as there is not a really good answer. i guess i just dont want to go that far yet.
  2. #2 Re: L32 power cabibilities on stock cam??
    around high 200's, low 300's.
  3. #3 Re: L32 power cabibilities on stock cam??
    Aug 2012
    Utah
    Wow, even with everything else, cam really holds them back that much?
  4. #4 Re: L32 power cabibilities on stock cam??
    new britain, ct
    Quote Originally Posted by Sevex View Post
    yes. lol. i doubt youd even reach 300 on a stock cam unless you went turbo.
    i still dont understand why you wouldnt cam put youd P&P your heads and LIM?
    07 Black GXP.
  5. #5 Re: L32 power cabibilities on stock cam??
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    i doubt you will even hit 300whp on that setup without a cam.
    300chp youll acheive.
  6. #6 Re: L32 power cabibilities on stock cam??
    Aug 2012
    Utah
    well damn, i just didn't realize that the stocker held it back that bad. OK what about this, with the above mods stated, what cam would be the best to get me to say 350 WHP? is that even possible with that setup? and i know its stupid to be asking for power and mpg but what kids of mpg are you guys getting out of cammed cars?
    cam, intercooler, heads.
    The M90 sucks that much, not the cam.
    There are apparently some magic tricks that can be performed to get past 350, like race gas. But people don't like to disclose those tricks.
    If your going though the trouble of pulling the everything off including the heads, then why not just cam it..your already there and its what like 5 more steps. Youll have to repeat the whole process over again if you do want to cam it later, which you will once you get it all back together and see theres not that much of a power difference without it
    Have you ever done either?
    Heads are pretty easy and straight forward compared to a cam.
    Unless you pull the engine.
    300 chp is easy.
    I made more than that on a gen III and L67 TB.
  8. #8 Re: L32 power cabibilities on stock cam??
    Heads is pretty easy and straight forward compared to a cam.
    My b, i mis read. I thought he was pulling it
    SMGPFC Member #10
  9. #9 Re: L32 power cabibilities on stock cam??
    SMGPFC Member #10
  10. #10 Re: L32 power cabibilities on stock cam??
    Indianapolis
    Turbo. Don't look back
  11. #11 Re: L32 power cabibilities on stock cam??
    Feb 2009
    flintnasty MI
    1.9 rockers and an intercooler will do 310-320whp high end.... And realistically it will probably be faster overall as the power curve will be a bit more flat. Cam will add another 20-25whp on top of that... and heads will add ??? on that.
    Switching out the roller tip rockers for modded stock 1.9's will probably give you another 20whp.
  12. #12 Re: L32 power cabibilities on stock cam??
    Aug 2012
    Utah
    I guess i just need to settle for what i have, I already have the 1.9's, Headers and injecters waiting to go on. I have a racecar and was hoping i could pep this up a bit so my wife could have some fun with it when we go racing. but at the same time i am not looking at starting another racecar project out of our daily. if i could snag 300-320 flywheel out of the that set-up with stock cam then i could prob live with that.....for now lol
  13. #13 Re: L32 power cabibilities on stock cam??
    Feb 2009
    flintnasty MI
    a 3.4 pulley car with a downpipe makes 300 crank....
  14. #14 Re: L32 power cabibilities on stock cam??
    It will easily make that. In fact I'd be disappointed if that was all it made.
  15. #15 Re: L32 power cabibilities on stock cam??
    Aug 2012
    Utah
    lol ok so i guess what i am asking is what should i see crank and wheel wise with the set-up i listed? any 1/4 times with a similar set-up?
  1. How much power can i run through stock wires?
    By RobGTP in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2011, 10:34 PM
  2. stock power diffrence kinda dumb.
    By RyanL in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2010, 12:03 AM
