Thread: How long will an L67 last?
Results 1 to 20 of 29
  1. #1 How long will an L67 last?
    GTX Level Member crbquist's Avatar
    Massachusetts
    My 01 GTP with the original l67 just rolled 112,000. My mods include an s1x cam, gen v, headers, etc. I am also piecing together a full size IC. Now I'm contemplating on buying heads.. Nothing too serious, maybe some cnc or stg 2 heads with 105's. I'm assuming my 112k bottom end should hold up if tuned correctly? It runs just dandy now.. Just like if not better than it did at 41k miles when I bought it back in early 07... Any thoughts? Should I proceed with the build?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: How long will an L67 last?
    Nov 2011
    NY
    Quote Originally Posted by crbquist View Post
    Hahaha... When going IC and heads, that IS serious, lol
    Personally I think it all depends. Going the route you are implys you will RACE the car and push it to extremes, with that comes risk, are you staying eight the S1X? With that added power you wil also be at the need for a built tranny... Etc. just my $.02
    Massachusetts
    Yup, staying with the s1x.. This will not be a race car, I just want more power for the street. I get on it from time to time, but overall I drive it pretty conservatively.
    Seems like going heads and IC route you may need to be interested in a tranny soon IMO. Instead of paying that much for CNC heads what about having a machine shop do a mild port and polish? But your bottom end should hold up but again there's always a exception.
    04 Comp G.
    Massachusetts
    Tranny is in mind as well.. Once my stocker takes a dump.. Was looking to have a machine shop port the heads but I don't know of any around where I live that have any experience with 3800 head porting. I also had a reputable source tell me recently that I am better off just buying some cnc heads than looking and trusting a machine shop to port mine.
  6. #6 Re: How long will an L67 last?
    Jan 2012
    Philadelphia
    A full size IC wont clear the SD hood just a heads up, you'll need cradle spacers
  7. #7 Re: How long will an L67 last?
    GTP Level Member buickman104's Avatar
    NYC
    If built and tuned correctly your bottom end will be perfectly fine. If you are willing to spend $2,000 on heads just go turbo and save more money.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
    A reputable machine shop around my area quoted me like $200 to do a port and polish but of course I'm going to have him check the heads for cracks Along with the valve guides so ill be a little bit more. Food for thought though P&P way cheaper than a 1k+ CNC heads. You could always send them off the be ported as well.
    04 Comp G.
    Massachusetts
    Quote Originally Posted by gtpeddie View Post
    It's a 2" IC, not the ZZP or wbs 2.25"
  10. #10 Re: How long will an L67 last?
    Mileage in sig. They last.
    Massachusetts
    Yes but heads, IC, cam, etc is more stress on the lower internals than your setup. Still, 226k is a milestone.
  12. #12 Re: How long will an L67 last?
    I'm ic soon. Might be camming sometime. I have an s1x laying in the garage.
  13. #13 Re: How long will an L67 last?
    Massachusetts
    You're really on a 226k motor? Ever do a gasket overhaul? Have the heads redone? I'm assuming the LIM gaskets were replaced......
  14. #14 Re: How long will an L67 last?
    Headgaskets never go bad (on a rare case they could), and I would mod a highmiles motor, it can take it.
    A mild port to the heads and cleaning the runners on the intake manifold can do alot. Said shop doesnt need to be one thats done many 3800's before.
  15. #15 Re: How long will an L67 last?
    Grand Rapids, MI
    Got a buddy with a stock l36 bottom end and he's working up 286k miles.
  16. #16 Re: How long will an L67 last?
    GT Level Member ls1camino's Avatar
    Laurel, MD
    450+ hp and daily driven...they last as long as you take care of them (oil changes).
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  17. #17 Re: How long will an L67 last?
    I did the lim gasket a few weeks back. Original motor and trans.
  18. #18 Re: How long will an L67 last?
    Portland Oregon
  19. #19 Re: How long will an L67 last?
    im running at 225,000 miles as well, stock engine. my guess these engines run right up until the day they dont any more.
    just did my lim gaskets last week too, it had plastic gaskets, i have no idea if they had ever been changed before. im like the 8 th owner.
    Massachusetts
    Quote Originally Posted by OH4CompG View Post
    That's insane
  1. Been gone for too long
    By tayl5645 in forum Off Topic Discussion
    Last Post: 06-22-2011, 12:31 AM
  2. How long will you keep your car?
    By hacket in forum Off Topic Discussion
    Last Post: 07-22-2009, 08:52 AM
  3. how long should a 99 gt last?
    By Zainoman in forum Off Topic Discussion
    Last Post: 06-16-2009, 10:54 PM
  4. How long does it take??
    By Sunstone in forum General Tech Discussion
    Last Post: 08-31-2008, 05:15 PM
