Thread: L67 heads, need advice.
Results 1 to 20 of 24
  1. #1 L67 heads, need advice.
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I am in the process of disassembling my heads to clean, do a mild hand P&P, and install new parts with my XP cam. There was nothing wrong with them before, the motor has 30k original miles on it, and had excellent compression before disassemble. I have an XP cam, with #105 springs, titanium retainers, comp cams valve locks, valve stem seals, also a new OEM timing chain and dampener on the way. I planned on reusing the stock rockers, valves, pushrods, and lifters. Is there anything I am forgetting? Also is re using the parts I mentioned advisable when going with this setup? Thanks for any advise or input!
    All the exhaust valves appear to be in the same condition, the first two pictures have been cleaned. The third shows the uncleaned valves, so should they be replaced? also any explanation as to why two of them are a completely different color compared to all the rest that are covered in carbon buildup? Could it be because maybe they were from the cylinders furthest from the EGR?
  2. #2 Re: L67 heads, need advice.
    Ohio
    yes, everything you plan to do is going to be fine,
    Only things needing replaced:
    Springs
    Valve Seals
    Retainers
    Valve locks/keepers
  3. #3 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    Quote Originally Posted by 99PGPGT View Post
    Springs
    Valve Seals
    Retainers
    Valve locks/keepers
    Thanks, I have done a ton of reading and figured this was true, but always great to get a personal response to verify, this is my first time inside of a 3800, so I am kind of nervous building the motor in my basement. A ton more wires, sensors, etc than what I am used to. Although I have done basic motor builds on other GM platforms such as 350sbc's etc
  4. #4 Re: L67 heads, need advice.
    Ohio
    its pretty simple when it comes to the wiring
    the harness practically lays itself into place perfectly for you.
  5. #5 Re: L67 heads, need advice.
    when i did my lim gaskets, i laid the harness back in place, one injector plug landed right on the injector, i was like click, thank you. lol
  6. #6 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    Yeah thats what I tell my self, I did a complete reseal on my DD a 99 buick century with a 3100sfi, harness looks scary, but it does just fall into place. Oh and my harness is some what modified, as the motor was in a Fiero... so it isnt the prettiest harness out there, hoping when I put the motor back in I can do a really neat tuck job.
  7. #7 Re: L67 heads, need advice.
    Sep 2012
    CT
    I would maybe get a quote on getting a valve job since you have it apart.. i had mine done along with a semi port job, chambers polished up a bit. I believe it made a huge difference in flow.
  8. #8 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    Quote Originally Posted by xx99gtpxx View Post
    I am doing my own polish/port job.
    ClubGP Message Forum troubleshooting
  9. #9 Re: L67 heads, need advice.
    You might want new exhaust valves.
    Depends how bad they are.
  10. #10 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    I did notice that the intake valves are perfect still and looks like new at the seals. The exhaust valve did have the slightest amount of markings on them where they would seal. I will post pics shortly to get opinions.
  11. #11 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    All the exhaust valves appear to be in the same condition, the first two pictures have been cleaned. The third shows the uncleaned valves, any explanation as to why two of them are a completely different color compared to all the rest that are covered in carbon buildup? Could it be because maybe they were from the cylinders furthest from the EGR?
  12. #12 Re: L67 heads, need advice.
    Sep 2012
    CT
    Quote Originally Posted by 88formula View Post
    ClubGP Messag Forum troubleshooting
    I understand that. I was just saying along with your port job, consider the valves too..
  13. #13 Re: L67 heads, need advice.
    Larger valves entirely defeats the purpose of budget.
    Machine shop won't let you walk out without having everything in order.
  14. #14 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    I ordered new stock size stainless steel exhaust valves today from ZZP, hopefully the weight difference in exhaust and intake valves won't be an issue, or I will have to upgrade the intake valves too even though they look to be in excellent condition. Also finished porting one port and bowl last night. Looks like this will be quite the process! Grabbing like 30 or 40 of our 80 grit tapered sanding bits when I leave work today lol
  15. #15 Re: L67 heads, need advice.
    Those are the SI valves.
    Which have a bad track record.
  16. #16 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    What do you recommend Matt?
  17. #17 Re: L67 heads, need advice.
    sealed power valves should be fine.
    They're supposedly the OE for some internal components.
  18. #18 Re: L67 heads, need advice.
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    I had 47k original on mine... Had the valves re-seated and the heads cut, do it while you have it apart!
    cost me $175 at local machine shop...
    Oh, and do your port work before you get them machined, they clean em off really good
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  19. #19 Re: L67 heads, need advice.
    Oct 2012
    West Branch, MI
    Yeah about cleaning them... I got pretty drunk last night while porting them (nothing better to do to pass the time)... Well I woke up not too long ago and checked them out. The port job looks good, but the problem is I had the great Idea to wash them in the dish washer like I did all my aluminum parts. They are now super clean and degreased, but entirely covered in a very light film of rust that I now have to deal with!
    Oct 2012
    New Jersey
    Lol. Have them soaked in parts cleaner, the rust will come right off.
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  3. N/A Advice... Heads?
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2010, 02:22 AM
  4. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
