Thread: confusing battery drain...help!!!
Results 1 to 13 of 13
  1. #1 confusing battery drain...help!!!
    michigan
    So i went out to my car this morning to a dead battery, new btw, replaced the alternator, still battery dying overnight! Everything is testing good, what else could it be? Ive made sure no lights or anything are being left on, just cant figure it out.
  2. #2 Re: cracked sc snout....wtf
    michigan
    Nvrmnd, did a google search on genv swap.....our search sucks. Sounds slightly more involved than i had imagined.
  3. #3 Re: cracked sc snout....wtf
    SWPA
    You could have left a light on to kill the battery.
  4. #4 Re: cracked sc snout....wtf
    michigan
    Checked that, i didnt. Im thinkin my alt isnt doing its job properly. In hindsight i just added one of zzp's voltage boosters to the alt. Maybe that killed it off. Not sure how old the alt is, was prob on its way out anyways.
  5. #5 Re: cracked sc snout....wtf
    antioch ill
    i got a thread going about gen 3 vs gen v
  6. #6 Re: cracked sc snout....wtf
    antioch ill
  7. #7 Re: cracked sc snout....wtf
    michigan
    I seen, thanx! Ill be following that as well as other ive seen. Not ready to do it right now, im laid off and moneys tight.
  8. #8 Re: cracked sc snout....wtf
    Pics of cracked snout?
    If its broken, just post up a wanted ad, someone might sell you one.
  9. #9 Re: cracked sc snout....wtf
    michigan
    Lmfao @ myself. There was grease/oil on the end of the snout. So i was gonna take a pic so i wiped the grease off and there isnt a crack, (thank god!) But the way the grease was on there looked like it was cracked. I felt so stupid, but yet soo relieved. I should've taken a pic the way it was, so ppl wouldn't have thought i was retarded! Lol
  10. #10 Re: confusing battery drain...help!!!
    michigan
    Still searching for the battery drain. Trying to look it over for any bad grounds, loose wires or anything else that i can think of without tearing apart the the whole electrical system. Any tips/common culprits i should be aware of?
    Dec 2010
    DMV
    Recently had this problem on my bros gt. apparently the starter screws weren't tightened. Just a thought. Also check for corrosion on the battery cables as well.
    Check the battery cables make sure they are right and not corroded also check the ground wire and make sure you don't happen to have anything plugged in or stuck in the cigarette lighter.
    04 Comp G.
  13. #13 Re: confusing battery drain...help!!!
    michigan
    I checked the starter, theyre tight but usual corrosion. Sanded all grounds i could find so far.
  1. Cracked Rim..Weld or Buy New Rim?
    By illtacticz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2012, 07:29 PM
  2. LIM cracked?
    By bobabooie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2011, 07:36 AM
  3. cracked windshield
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-20-2011, 06:48 AM
  4. cracked heads
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 01:07 PM
  5. Cracked windshield
    By wayne1981 in forum Visual/Body Modifications
    Last Post: 12-16-2007, 10:42 AM
