Thread: Leaky pcv
Results 1 to 16 of 16
  1. #1 Leaky pcv
    Wichita
    Pulled the supercharger today to replace my lim gaskets. And what I found was oil on the underside of the supercharger at the bottom of the pcv valve. I also noticed that there was something jammed in the pcv breather hole. It was the plastic cone or whatever that thing is that goes right underneath the pcv valve. Is that peice of plastic supposed just sit in there with the pcv valve on top of it? Im also guessing my pcv valve is bad since there was supercharger oil everywhere, would I be right? Any help, thx.
    Ohio
    It's not supercharger oil, that's only in the snout. It's regular oil
    Sent from my DROIDX using Tapatalk
  3. #3 Re: Leaky pcv
    Wichita
    Oh. I should've known that. Silly me. So then the oil probably came up into the pcv valve by way of my lim gasket leak?
  4. #4 Re: Leaky pcv
    just replace it, its like 5 bucks.
    the oil on the bottom could be from the LIM.
    if your not burning any oil or losing alot, i wouldnt worry alot about it.
  5. #5 Re: Leaky pcv
    Wichita
    I will replace it tomoro. But until then i put it all back together properly & its amazing how great my car runs now! Its crazy how sensetive these motors are to vacuum leaks.
  6. #6 Re: Leaky pcv
    The pcv has oil on it.. from the positive crankcase ventilation. Totally normal, as is the piece below it.
  7. #7 Re: Leaky pcv
    Wichita
    It was enough oil to soak the supercharger gasket causing it to fail.
  8. #8 Re: Leaky pcv
    Gaskets should not get ruined by fluid touching them. Their job is to gasket two things. Definately check your pcv, normal operation though is for that little plastic piece to catch some of the oil and send it back down.
  9. #9 Re: Leaky pcv
    SE Level Member Comanche1959's Avatar
    Nov 2010
    Kentucky
    Saw this thread and want to ask a question. I have an '01 GTP with 118K miles and have noticed that I'm starting to see a little oil consumption that I never had before. My mileage has also dropped about an average of .7mpg for identical daily driving of 20 miles to/from work.
    Have owned car since new and change oil every 3,000mi religiously.
    Could that be caused by a PCV going south?
    Steve
  10. #10 Re: Leaky pcv
    it couldnt hurt to change it.
    but GM does say 1 quart for every 3k miles is normal.
  11. #11 Re: Leaky pcv
    Nov 2010
    Kentucky
    I'd estimate it using about a qt every 1600 miles. Definitely no oil leaks....had the intakes and oil pan gasket replaced with the newer dealer gasket / sealant awhile back and have never had another leak.
    Is the pcv easy to locate and get to?
    Steve
  12. #12 Re: Leaky pcv
    its right ontop of the supercharger, you cant miss it. Says PCV right on it.
  13. #13 Re: Leaky pcv
    Nov 2010
    Kentucky
    Duh....figure that'll be a quick one. I'll change it and see what happens.
    Thanks,
    Steve
  14. #14 Re: Leaky pcv
    Nov 2010
    Kentucky
    Long time since last post, but I changed PCV and still have a slight amount of oil consumption. No oil leaks at all. I've been changing oil in 3-5,000 mile intervals, with 10W30 Valvoline regular oil. It's an every day driver and my daily commute is 10 miles each way....about 15 minutes of non interstate driving.
    Have about 124,000mi and car runs great.
    Steve
  15. #15 Re: Leaky pcv
    Wichita
    Could be a leaky lower intake manifold.
    Could be LIM or could be a bad valve seal?
    04 Comp G.
  1. Leaky ZZP FPR?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 08-31-2011, 07:53 PM
  2. leaky tail light lense
    By chumley in forum General Tech Discussion
    Last Post: 12-20-2010, 01:43 AM
  3. Leaky LIM
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2009, 02:23 PM
