Thread: Airbag light, wheel controls, horn doesn't work.
Results 1 to 9 of 9
  1. #1 Airbag light, wheel controls, horn doesn't work.
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I bought this 98 GTP that had a bad trans. Pulled motor, swapped trans, put the car back to stock. Everything runs fine except:
    Air bag light on, cruise doesn't work, steering wheel controls don't light up (or work) and the horn doesn't work.
    The brake lights work, wipers, turn signals, brights/headlights work fine.
    I thought it might be the turn signal switch in the column. I don't think that's it because everything worked fine before I pulled the motor/trans.
    I've checked the fuses and connectors under the dash where the harness plugs in for the switch.
    When I pulled the motor/trans I didn't drop the cradle. Everything came out the top and the steering was never disconnected. Before I go to pick n pull to get a switch what else can I check? Grounds? Where?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    I'd say clock spring or in the wiring to the clock spring.
    Sent using Tapatalk 2 from my GS3.
  3. #3 Re: Airbag light, wheel controls, horn doesn't work.
    id think clock spring as well. the horn, could be the wires under the air bag, the wires under the hood to the horn, or the horn its self is dead.
    either way the steering wheel needs to come off to get to the clock spring.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    X2 on the clockspring.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Airbag light, wheel controls, horn doesn't work.
    Aug 2011
    Gahanna, Ohio
    Changed the clock spring. No go. Horn doesn't work on the wheel but when I hit the lock button twice it blips. I found the steering wheel control issue which was a fuse I must have missed.
    Checked the relays, Kinda stuck. Any other ideas?
  6. #6 Re: Airbag light, wheel controls, horn doesn't work.
    the 2 wires from the air bag were plugged in? the long black one that you push in the column and twist, and the one that sits on a stud?
    for the abs light, next step is to look under your front seat, see if you have a yellow plug, if so open it, clean it put it back, if that dont fix it, under the pass seat, and then under the rug is a air bag module, it was the cause of my air bag light. i changed it and the light was off instantly.
    my guess is if the cowl leaks, the floor gets wet and over time kills the module.
  7. #7 Re: Airbag light, wheel controls, horn doesn't work.
    Aug 2011
    Gahanna, Ohio
    Awesome. I'll have to check that out tomorrow. I'm done being in the garage today. I'm selling the car. I just want to get rid of the air bag light.
    Yeah the wires from the air bag were plugged in and the one that twists. Still stumped on the horn.
  8. #8 Re: Airbag light, wheel controls, horn doesn't work.
    i got my car cheap because every light on the dash was lit up lol, all in all it cost under 100 to turn them all off. that air bag module goes for as cheap as 20 or as high as 40, or in your tool box real easy at a pick and pull yard. where mine came from.
    funny i just saw where your from. (my module came from ohio, from another member snatched it up for me)
  9. #9 Re: Airbag light, wheel controls, horn doesn't work.
    Aug 2011
    Gahanna, Ohio
    Yeah I was just at the yard on Friday to get the clock spring. Didn't know about the air bag module
  1. Horn doesn't work, any help?
    By hockeybawler in forum General Tech Discussion
    Last Post: 10-10-2012, 10:30 PM
  2. Replies: 3
    Last Post: 08-16-2012, 02:20 PM
  3. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. howto make Steering wheel controls work???
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 05-16-2009, 03:04 AM
