Thread: Keeping Heads from rusting
Results 1 to 6 of 6
  1. #1 Keeping Heads from rusting
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I have some used stage 3 ported heads I just purchased....I won't be able to install them untill around January. How do I keep them from rusting?
    Sent from my SGH-T989 using Tapatalk 2
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
    Give them to me and ill install them ASAP so they don't rust?
    I think most guys just rub wd40 or some kind of oil on then I'm not mistaken.
    04 Comp G.
  3. #3 Re: Keeping Heads from rusting
    spray wd40 all over them.
    Bowie, MD
    Cool I have them in the bags pictured also.....so spray wd-40 once and bag them up correct?
  5. #5 Re: Keeping Heads from rusting
    yep and just check on them every so often.
  6. #6 Re: Keeping Heads from rusting
    i would soak everything you just bought in wd-40, and then bag it all. everything in your pics can rust. keeping them indoors in a climate controlled area is a good idea too.
    if you were storing them for longer i'd recommend a vacuum bag, one of them food savers deals.
  1. Rusting Help
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 10-26-2011, 06:21 PM
  2. Rusting already?
    By Ninny in forum Visual/Body Modifications
    Last Post: 10-28-2009, 12:08 AM
  3. rusting?
    By Poil336 in forum Visual/Body Modifications
    Last Post: 08-29-2009, 07:11 PM
  4. rusting?
    By Poil336 in forum Shops and Community Heroes
    Last Post: 08-28-2009, 07:38 PM
  5. rusting
    By GMPUNK in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2009, 05:00 PM
