Thread: ticking noise
Results 1 to 20 of 27
  1. #1 ticking noise
    House springs missouri
    so I took my car to the salvage yard earlier today in my 98 gtp it was running fine with no problems a little bit after I got back I went out to clean it up and started it to use the heat and it started making a rattling slash ticking noise so I pulled the belt from the supercharger because it sounded like it was from the supercharger it's still making the noise it sounds like it's coming from around the supercharger or the front valve cover I can think of what it could be what is starting that sudden
  2. #2 Re: ticking noise
    coupler?
  3. #3 Re: ticking noise
    coupler?
    it's coming from the driver side
  4. #4 Re: ticking noise
    when I bring the RPM's up the ticking noise isn't as loud
  5. #5 Re: ticking noise
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Check for loose spark plug or bad plug wire, they can tick loud at idle and smooth out under acceloration. If both of those turn out ok, it could be a lifter...
    Mechanics stethoscopes help out A LOT finding odd noises.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  6. #6 Re: ticking noise
    it might be a lifter because it was actually making a slight ticking noise the would go away at higher rpm's a couple weeks ago and I put motor honey in the oil and it got quieter so I don't know if its the same noise that came back or what. Is it possible that a lifter could have been loose and the motor honey cushioned the lifter and it just loosened more or could it be more serious.
  7. #7 Re: ticking noise
    Oct 2012
    New Jersey
    A loose lifter = bad cam lobe or bad push rod... Definitely worth looking into.
  8. #8 Re: ticking noise
    how will that cost to fix
  9. #9 Re: ticking noise
    Oct 2012
    New Jersey
    Well, lifters don't usually go "loose" bad maybe, but not loose. If you have just a lifter tap with no other problems then just plan to change the lifters...
  10. #10 Re: ticking noise
    Quote Originally Posted by JerzNick View Post
    ok thank you for the help
  11. #11 Re: ticking noise
    From the drivers side it could be the flex plate.
  12. #12 Re: ticking noise
    ok ill check that too
  13. #13 Re: ticking noise
    I took off the valve cover last night and it is not the lifters I remember when the nouse started I lost boost is it possible that a bearing fell into my motor from the supercharger
  14. #14 Re: ticking noise
    Not likely
  15. #15 Re: ticking noise
    what could it be coming from under the supercharger
  16. #16 Re: ticking noise
    How do you know it's not a lifter? Take a video of it.
  17. #17 Re: ticking noise
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    yep take a video of the sound. I'm think lifter or bearing.
    97 Bonneville SE Not so much a 97 anymore
  18. #18 Re: ticking noise
    tennessee
    or balance shaft bearings, they sit directly under the lim...
  19. #19 Re: ticking noise
    none of them were loose and I started it when I the valve cover was off and it didnt sound like it was coming from there
  20. #20 Re: ticking noise
    Quote Originally Posted by Eric Whitter View Post
    It would be hard for a lifter to be loose since it sits between the cam and pushrods.
  1. Ticking noise ?
    By thegipper in forum General Tech Discussion
    Last Post: 08-01-2012, 05:50 PM
  2. what is this ticking noise?!?!?
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 07:36 AM
  3. Ticking noise
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 10:22 PM
  4. ticking noise
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2011, 10:52 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
