Thread: Top swap not making power! Help
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 103
  1. #81 Re: Top swap not making power! Help
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    So instead of the 2 lines coming from the throttle body, just use a fat one to go from the throttle body to the thick line in the pic going to the evap canister??
  2. #82 Re: Top swap not making power! Help
    tb to evap SOL. evap to the canister.
  3. #83 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Heres what I just did. I did one big hose from the throttle body to the evap canister. regulator and map sensor are going to the LIM. BBV is connected on top. Bottom of BBV is open. Still getting 2.9lbs of boost. Any other suggestions?
  4. #84 Re: Top swap not making power! Help
    wheres the vac line to the by pass solenoid? like in post 48 of this thread? fuel pressure reg gets a T then to the by pass solenoid.
    i know you have things all this and that way, so it makes it hard to tell just what is going on completely.
  5. #85 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I don't have anything going to the bypass solenoid. Some one on here posted a video showing his vac lines and he didn't have anything going to the bypass solenoid. He said its not needed
  6. #86 Re: Top swap not making power! Help
    well maybe that guys wrong. put a T on the fuel pressure reg, and then off to the by pass. see what happens. at least thats closer to the way it should be.
  7. #87 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Maybe, but he's putting out good boost. I'll give it a try. Theres 2 connections on the other side of the bypass solenoid, what do I do with those? the diagram shows to run a line from one of them to the bottom of the BBV. Is that correct?
  8. #88 Re: Top swap not making power! Help
    one of the nipples is supposed to be free of anything, its supposed to have a sponge like filter on it.
    i think its got 2 clips on the sides of the vac nipple, iirc the open one is the top one, the lower one gets hooked up to the by pass actuator. if im remembering right.
    its a long walk to my car to check or i would.
  9. #89 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I hooked everything up exactly to what the diagram is. tried both nipples on the bypass solenoid and still only 2.9lbs.
  10. #90 Re: Top swap not making power! Help
    when you goose the gas from under the hood, does the lever on the by pass actuator move? you can do this in park.
  11. #91 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I didn't look for that. Is it supposed to move? and if it doesn't?
  12. #92 Re: Top swap not making power! Help
    its supposed to move. when the cars off you should be able to move it up and down with ease.
  13. #93 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I just checked, the actuator does move.
  14. #94 Re: Top swap not making power! Help
    thats good news.
    hows the idle now, any smother?
  15. #95 Re: Top swap not making power! Help
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    the solenoid doesnt do anything other then limit boost by cutting vacuum supply if the PCM hits abuse mode. No need to hook it up. Is the BBV valve opening when the throttle is snaped. It should hit the little allen stopper on the blower case and then should go directly back up smoothly.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  16. #96 Re: Top swap not making power! Help
    Hagerstown,Md
    If the idles off then I would think you might have a huge vac leak. Whats the fuel trims reading at idle?
  17. #97 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    The BBV opened up fine. Not sure on the fuel trims. I'll check later. But the idle seems fine just has a cam chop to it
  18. #98 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    my short and long trims were all over. long trim B2 is around -2.3. Long trim B1 around -3.1. Short trim B1 ranged from around -2 to around +3. Short trim B2 around -2.3
  19. #99 Re: Top swap not making power! Help
    Hagerstown,Md
    fuel trims are fine so no vac leak as long as thats the readings with your foot off the gas
  20. #100 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Yes those are the readings with my foot off the gas. I hooked everything up like the diagram and still 2.9lbs. I'm lost. Don't know what else to do. I tried disconnecting the BBV and capped the top and still 2.9 lbs. Any other suggestions?
  1. not making the power
    By sprattzvx in forum PCM Tuning
    Last Post: 10-18-2011, 03:47 PM
  2. Replaced Power Steering pump, now making noise.
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-14-2011, 03:06 PM
  3. Possible to swap mirror from standard to power?
    By cboth686 in forum General Tech Discussion
    Last Post: 08-15-2010, 12:45 AM
  4. More Low/Midrange power... without doing a top swap.
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 08:20 AM
  5. Making a L67 RWD...My S10 swap plans
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-19-2009, 11:38 PM
