Thread: p0102 and weird noise on shut off
Results 1 to 16 of 16
  1. #1 p0102 and weird noise on shut off
    GT Level Member m17davis's Avatar
    Orland Park, IL
    hey guys. obviously i have a P0102. i have all new sensors on the tb and im not sure what it is. the weird thing is that when i turn the car off there is a stange noise coming from right between the altenator and blower. it sounds like pressure is being released right after the motor shuts off. should i unplug the o2 sensor, then try it? or how about the maf?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: p0102 and weird noise on shut off
    unplug the maf sensor and see if it runs better or take a video of what it's doing.
  3. #3 Re: p0102 and weird noise on shut off
    Pennsylvania
    Check the rubber T under the sc snout. Might be where the noise is coming from.
    P0102 has nothing to do with the O2 sensor.
    It's a MAF code. Check the connection on the maf, make sure there's no shorts, clean the maf.
  4. #4 Re: p0102 and weird noise on shut off
    check the wires at the plug for broken insulation or cracks, bad wires to the maf will toss the same code as a bad maf.
  5. #5 Re: p0102 and weird noise on shut off
    Orland Park, IL
    well i found a blown fuse to the maf. then i threw a o2 code. idk it tho. it said something about a heater low voltage i think. and the vaccum line is new that raps around the blower
  6. #6 Re: p0102 and weird noise on shut off
    If the fuse blows again you have bad wiring or a bad maf.
  7. #7 Re: p0102 and weird noise on shut off
    Orland Park, IL
    well im not throwing any codes but my idle is pretty bad. and when i turn the car off it sounds like pressure is being released above cyl 2 injector. its not the evap canister purge solenoid. i switched it from my other car. and i unplugged the map sensor and it didnt change. any ideas? im currently trying to upload a video to youtube..
  8. #8 Re: p0102 and weird noise on shut off
    Orland Park, IL
  9. #9 Re: p0102 and weird noise on shut off
    its private
  10. #10 Re: p0102 and weird noise on shut off
    Orland Park, IL
    sorry. fixed it
  11. #11 Re: p0102 and weird noise on shut off
    Pennsylvania
    Lol, looks to me like its your boost bypass making the noise.
  12. #12 Re: p0102 and weird noise on shut off
    Orland Park, IL
    haha. i know its ruff but ive had that for a couple years. i checked it already and its fine. is there anyway it could be coming from somewhere lower than the valve cover?
  13. #13 Re: p0102 and weird noise on shut off
    Pennsylvania
    Wait... you unplugged the MAP... meaning you disconnected the electric? Or you disconnected the vacuum line? If you disconnected the vac line and nothing changed, then that would point to a vac leak earlier in that line.
  14. #14 Re: p0102 and weird noise on shut off
    Def vacuum leak. Check the brake booster line
  15. #15 Re: p0102 and weird noise on shut off
    Orland Park, IL
    i unplugged the electric connection. my boost gauge says 16 on the vac side. is that normal or high. from my memory it has always been there. so i dont think its a vac leak. it literally sounds like its coming from right between the alt and map...
  16. #16 Re: p0102 and weird noise on shut off
    why would you unplug it?
  1. Weird noise?
    By Points70 in forum General Tech Discussion
    Last Post: 10-19-2011, 12:18 PM
  2. Weird noise
    By redgrandprix77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2011, 06:15 AM
  3. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
