Thread: What spark plugs to use
Results 1 to 8 of 8
  1. #1
    SE Level Member charlie31603's Avatar
    Jul 2008
    Tampa, Florida
    I only get a small blip of knock when letting off or or shifting at WOT. Recently I have been getting some knock under light throttle, with a load on the engine between 1k-2k rpm.
    Sent from my DROID RAZR using Tapatalk 2
    1999 Pontiac Montana with a loud whine
  2. #2 Re: What spark plugs to use
    Pennsylvania
    Buy 606 coppers, 0.60" gap. If she's happy, swap to 606 iridiums so you don't have to keep changing spark plugs (or don't if you like the chore).
    If she's not happy, try 605 coppers. If she's still not happy, then you broke something.
    Quote Originally Posted by charlie31603 View Post
    You didn't tell us what your current spark plugs are, so they could be the issue. Old version ZZP wires make knock, and I'll bet your tune isn't as dialed-in as you think it is.
  1. spark plugs
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2013, 03:34 AM
  2. spark plugs
    By 99gtp3 in forum General Tech Discussion
    Last Post: 07-11-2012, 07:45 AM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. what spark plugs should i get?
    By asite57 in forum General Tech Discussion
    Last Post: 02-05-2012, 01:19 PM
  5. Which Spark Plugs Should I Run?!?
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 08:27 PM
