Thread: Engine stuttering on hard acceleration
Results 1 to 20 of 23
  1. #1 Engine stuttering on hard acceleration
    SE Level Member zeppelinrocks18's Avatar
    Hello everyone. I just joined GPF and I already have a problem. I have a 1998 Grand Prix GTP. Just recently, I noticed that on hard acceleration, my car will stutter, almost as if it's misfiring, and accelerate rather sluggishly. It makes a kind of bubbling sound/feeling. That's the best way I can describe it. When I do a nice smooth acceleration, there is no problem at all. I gapped and changed all of the spark plugs recently. I am trying to figure out if it is possibly an ignition coil, a bum spark plug, or possibly a fuel injector. Does anyone know a way to tell if it is any of these? I don't think it could be a spark plug seeing how the problem does not happen all the time, only on hard acceleration. If anyone knows anything, please let me know. Thank you so much.
    1998 GTP, 118K, Short Ram Air Intake, ACDelco RapidFire Plugs, Belden Wires, Resonator and U-Bend delete, Flowmaster Original 40 Series, KYB GR-2 Struts, 180* Thermostat
  2. #2 Re: Engine stuttering on hard acceleration
    Jan 1970
    Maquoketa, Iowa
    Most people run autolite 104's at your level and gap to .054
    Do you scan your car for knock? It looks like you have a HAI.
  3. #3 Re: Engine stuttering on hard acceleration
    SE Level Member SLO-6's Avatar
    Aug 2008
    Texas
    I just recently found that i am having the same problemm
    Eaton M90 S/C, Thrasher Engineering CAI (soon a FWI By: TDC RACING, MSD Wires. ZZP 3'' Stainless Catback Exhaust, Northstar TB KIT, ZZP 3.4 Pully Swap
  4. #4 Re: Engine stuttering on hard acceleration
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by zeppelinrocks18 View Post
    What did you gap them at? Too large of a gap can cause spark blowout during hard acceleration, and would explain why your car is stuttering up top. I would check the plugs regardless of what they were gapped at though, cause it may turn out to be a cracked plug or something.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  5. #5 Re: Engine stuttering on hard acceleration
    Feb 2008
    Quote Originally Posted by Smokin2000gtp View Post
    HUH
    I had to look it up, never heard of it.
    http://www.superchargersonline.com/content.asp?ID=11
  6. #6 Re: Engine stuttering on hard acceleration
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    when i changed my plugs and wires i had the same exact problem ..it would drive perfect until i got on it and then my car would barely go and a bad sound would come from the exhaust in the back........ i had a bad # 3 plug.....i bought a new spark plug and put it in and everything was fine after that ..so maybe check all the plugs with a new one.....
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  7. #7 Re: Engine stuttering on hard acceleration
    SE Level Member Mikefisher's Avatar
    Winkler,Manitoba,Canada
    sounds like the same thing to me.Go hard and the car felt like it missed fired.But all of that lead up to the job I am doing now. I still hope that I do not have to get to the heads.Have all the intake off now and wondering if I should rip off more.
    Pike---- Family of rapacious,malevolent,razor-toothed freshwater game fish that will strike instantly and violenty at just about any lure you decide not to try...
    http://s43.photobucket.com/albums/e381/mikefisher99/
  8. #8 Re: Engine stuttering on hard acceleration
    I just talked to a friend that's a mechanic and he said that it could possibly be a clogged catalytic converter. He said it acts kind of like a rev limiter on the car and makes that bubbly feeling/sound. I also found out W-Body's are common for cat's clogging up. I am going to check that first and see.
  9. #9 Re: Engine stuttering on hard acceleration
    Aug 2008
    SOUTH TEXAS
    Is it throwing any codes?
    If it is check on here to see what it is:
    OBD-2 V6 FWD Diagnostic Troube Codes
    Or go to an autoparts store to get it scaned.
    Let us know if you find the problem.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  10. #10 Re: Engine stuttering on hard acceleration
    Jul 2008
    Dekalb, IL
    Wouldn't checking the plugs be easier? Lots of people crack their plugs while installing them.
  11. #11 Re: Engine stuttering on hard acceleration
    It isn't throwing any codes. So it's not the O2 sensor. I am going to check the plugs first and then see if anything is cracked.
  12. #12 Re: Engine stuttering on hard acceleration
    Hey again. I am still having the problem with my car although there now is a sound coming from my exhaust when I accelerate that sounds like change in a coffee can, making me think the honeycomb in the cat came lose. I checked the plugs and they are fine. I assumed they were too because during a slow acceleration up to the high RPMs, there was no stutter. There would be the stutter under heavy load no matter the speed of acceleration or just all the time if it was the plugs. What I am curious about is with OBD-2, which cat can I buy? Magnaflow has converters that are universal and around 67 bucks but they state they are OBD-2 compliant. I'm looking at the part number, 99306HM, and I am curious as to whether I can buy that and just have it welded it. That would be awesome and save me some money. Let me know what you all think.
    On Magnaflow's website, they show this converter as being the correct one, and I called them and said their universal converters are all OBDII Compliant.
    http://www.car-sound.com/02product/d...versal=99306HM
  13. #13 Re: Engine stuttering on hard acceleration
    Nov 2008
    Iowa
    I am having the same problem - I have noticed that with the blower drive belt removed, the problem goes away, or at least it seams to. (By the way, with the blower belt off, I pick up 4 to 5 mpg.) Anyway, I am leaning towards the cat-converter also. I hate to buy one if that's not the problem as it will run right around $200 just for the part. Has anyone replaced their converter and resolved this problem?
  14. #14 Re: Engine stuttering on hard acceleration
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Mine did the SAME thing! Mine was bottom coil pack 1,3 I think.
    The only code my car threw was O2 sensor. Replaced it and it still did it. My car would get worse the longer I drove it. (as it got warmer?)
    I say start with the cheapest simplest thing first, then go up from there.
    Coil Pack at O'Reilly (here) $30.
    Let us know what you find out. Good Luck!
  15. #15 Re: Engine stuttering on hard acceleration
    Nov 2008
    Iowa
    I have changed out the plugs with AC Delco Iridium plugs, and new lifetime warranty 8mm plug wires. I also removed all three coil packs and had them checked out. All three are in good shape. I get a code that comes up "exhaust inefficiency". So now, with the blower belt removed, there is less air going thru the exhaust and the shudder has gone away. Has anyone replaced their cat converter and resolved the shutter?
    The code that pulls up is number 0420 "catalyst system low efficiency". The local parts store doesn't know what this means. Anyone know?
  16. #16 Re: Engine stuttering on hard acceleration
    Aug 2008
    Texas
    Well i was having the same problem, but went and just bought a bunch of stuff i planned on buying anyways lol
    Reprogrammed PCM
    MSD Wiring/ Coils
    Magnaflow Exhaust (cat-converter)
    but from a local mechanic he specifically said check plugs and wires
  17. #17 Re: Engine stuttering on hard acceleration
    Nov 2008
    Iowa
    Like I said, new plugs and wires - plugs gapped properly. Has anyone replaced the cat converter and found this to be the real problem?
  18. #18 Re: Engine stuttering on hard acceleration
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by Blown97 View Post
    HUH
    SuperchargersOnline.com :: The Skinny on Spark Plugs
    Ya I had to learn the hard way what spark blowout was lol.
    X2 First do new plugs gapped properly, if that doesn't help replace the wires. It's unlikely for the cat to cause symptoms like this but it's not unheard of. If you think your cat is the problem you could scan the car to see if you are boost stacking from the clogged cat.
  19. #19 Re: Engine stuttering on hard acceleration
    Nov 2008
    Iowa
    To Smokin200 GTP: Check out my 11-07 posting. I have changed both the plugs and the wires. Also, I keep getting a check engine light: The code that pulls up is number 0420 "catalyst system low efficiency". The local parts store doesn't know what this means. Anyone know?
    There are sensors both in front of and at the end of the cat converter - I'm guessing that "catalyst system low efficiency" means a larger than normal pressure differential across the cat converter. That's why I keep asking "has anyone replaced a converter????
  20. #20 Re: Engine stuttering on hard acceleration
    Jul 2008
    Dekalb, IL
    Oh didn't see that you were throwing that code. It's definitely a plugged up cat then. Get it either replaced, deleted, or gutted and your good to go.
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. Replies: 6
    Last Post: 10-11-2008, 09:30 PM
  3. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
  4. HOW to and is it HARD?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-10-2008, 10:37 PM
  5. No Acceleration issue
    By BooGTS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2008, 08:16 AM
