Thread: To build bottom end, or not to build bottom end?
Results 1 to 20 of 20
Stephen Shaw To build bottom end, or not... 11-05-2012, 09:25 AM
REDCRAPGP Usually our bottom ends never... 11-05-2012, 09:30 AM
QUICKSILVER462 Re: To build bottom end, or... 11-05-2012, 11:54 AM
Sushamouf ^ This The bottom end is... 11-05-2012, 12:27 PM
matt5112 Who's charging 500 for a... 11-05-2012, 01:52 PM
GOTIT4CHEAP16 Re: To build bottom end, or... 11-05-2012, 07:34 PM
Stephen Shaw Re: To build bottom end, or... 11-06-2012, 11:50 AM
darkhorizon Re: To build bottom end, or... 11-06-2012, 10:33 PM
blueguy Re: To build bottom end, or... 12-11-2012, 12:53 PM
GOTIT4CHEAP16 Dyno tune is the best way to... 11-06-2012, 10:51 PM
OrangeL67 Re: To build bottom end, or... 12-11-2012, 12:28 AM
MoarkatsINmuhtrailer Lol... Well... Not really...... 12-11-2012, 12:52 AM
matt5112 Re: To build bottom end, or... 12-11-2012, 03:15 PM
crbquist I picked up power from having... 12-11-2012, 06:52 PM
matt5112 Re: To build bottom end, or... 12-11-2012, 06:54 PM
crbquist The maf and injectors were... 12-11-2012, 08:24 PM
matt5112 Re: To build bottom end, or... 12-11-2012, 09:54 PM
OrangeL67 Re: To build bottom end, or... 12-11-2012, 11:29 PM
GTPpower Re: To build bottom end, or... 12-12-2012, 02:06 PM
REDCRAPGP I'm guessing its because it... 12-12-2012, 02:19 PM
  1. #1 To build bottom end, or not to build bottom end?
    SE Level Member Stephen Shaw's Avatar
    Apr 2012
    So I had these big plans to rebuild my motor, but due to recent events I'm now broke and i'm looking to get my GP on the road as cheap as possible, and as soon as possible.
    So the engine itself has 220,000 KMs (136,701 Miles), I was going to put all new bearings and piston rings in, but keep the orginal pistons and connecting rods.
    Parts that I already purchased, and that I plan on putting in:
    XP Cam/Valve springs/modified retainers/valve seals
    timing chain/dampener
    ARP Head studs
    My thoughts are, if a spin a bearing, i'll take the engine out and find one with lowers KMs to put my cam and stuff in. If a pistion or connecting rod goes, it would have went anyways because they would still be the orginal ones.
    I still have to pay $500 to have the car tuned too.
    What are your thoughts? Are these bottom ends good for high miles?
    Usually our bottom ends never take a dump until they've been messed with or attempted to be swapped. You should be fine.
    04 Comp G.
  3. #3 Re: To build bottom end, or not to build bottom end?
    HUDSON
    If you have the knowledge, patience, and tools to check clearences and dimensions, then by all means re-build the bottom end, if not, find a REPUTABLE machine shop that is up to the task. If that is not a viable option than find a good-used factory short/long block and go from that as a starting point for an engine build.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    ^ This
    The bottom end is not "magical or cursed" on the 3800, the only reason they would fail after a rebuild is ignorance. It's just like every other engine... if you don't know what you are doing, have someone who does do the work. I say have a GOOD machine shop work the block. If you are doing head studs, have them do a torque plate hone.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
    Who's charging 500 for a tune?
    Where are you located?
  6. #6 Re: To build bottom end, or not to build bottom end?
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Im paying $500 to get my car dyno tuned also in va.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  7. #7 Re: To build bottom end, or not to build bottom end?
    Apr 2012
    Raven Autosports (James) is doing it. You guys probably know his car, the Cavalier with the turbo 3800. I'm located in Nova Scotia, Canada.
  8. #8 Re: To build bottom end, or not to build bottom end?
    Feb 2009
    flintnasty MI
    you shouldnt really ever need to tune a 3800 car beyond just flashing some garbage on it that makes it run right..... 500 for a tune is easily the worst way to spend money on your car.
  9. #9 Re: To build bottom end, or not to build bottom end?
    And no, dyno tunes are for goobers.
    Street tuning or nothing. All a dyno is good for is for maximizing gains on a setup with AWESOMECOOLNUMBERSSS.
    You don't go WOT everywhere, so tune your car on the street like it should be. In all sorts of situations. In every gear, at multitudes of different speeds.
    You never cease to amaze me.
    Bowie, MD
    Dyno tune is the best way to get a good running cammed built car(380")
    Sent from my SGH-T989 using Tapatalk 2
  11. #11 Re: To build bottom end, or not to build bottom end?
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Quicksilver is right. End of the day, the 3800 was built by someone on an assembly line. GM follows strict guidlines regarding torque specs & oiclearences. Thee 3800 is a very reliable engine because of this. And it shouldn't be a surprise that they are not reliable when these details are overlooked. Also, the variation of rod weight can be extremely wide. I found out that 1 of my l32 rods weighed 14.9 grams more than another (from the same engine). 14 grams of unbalanced weight at 6000 rpm is at least 600 pounds of crank flexing force from that 1 rod alone. This explains why some 3800's are fine being revved to 7k rpm, and some break at 6300. It is important to balance any 3800 that will be used with a big cam at high rpm. GM obviously didn't pay close attention to the balance, probably because they used pretty beefy parts in thier supercharged applications and they were intended to handle boost, but not necessarily high rpm's.
    Tricky little bastards I tell you.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
    Ohio
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Lol... Well... Not really... But ok
  13. #13 Re: To build bottom end, or not to build bottom end?
    well what do you REALLY do here?
    Bump the maf around a little, bump the timing around a little, change the shift points and line pressure.
    Not exactly $500 worth of work.
    Tunes don't really do much with a 3800.
    Its not like you can add 10* of timing and pickup power, or lean it out a point or two and pickup power, or increase boost targets and pickup power.
    Its just not in the cards.
    GTX Level Member crbquist's Avatar
    Massachusetts
    I picked up power from having all those parameters adjusted.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  15. #15 Re: To build bottom end, or not to build bottom end?
    How much were these parameters adjust by? What sort of tune did you have beforehand?
    Just looking at your mod list, you'd need a tune because you've stuck injectors in there with no known calibration (which are also of an ancient design, worse than the factory injectors), and a larger TB which some claim to have tuning issues with. Larger MAF also requires adjustments.
    So I wouldn't doubt it was running pig rich or way too lean.
    Tuning isn't magical. Get fuel and spark in order and you're done.
    Feel like I'm repeating myself.
    Massachusetts
    The maf and injectors were dialed in upon completion of my cam install. Then my car was running pig rich with an afr in the mid 10's, so a full point was taken away along with bumping the timing a few degrees and the car suddenly felt like it picked up a good amount of power. I'm doing heads and an IC this winter, so I am assuming I will be in need of a better tune come then.
  17. #17 Re: To build bottom end, or not to build bottom end?
    What you described is pretty basic tuning, nothing special.
    If your tune was done correctly the first time, the intercooler shouldn't change anything.
    Perhaps you'll need fuel a little sooner with the smaller pulley though.
    But that doesn't constitute the phrase "better", just more accurate for your modifications.
  18. #18 Re: To build bottom end, or not to build bottom end?
    Nov 2009
    Michigan
    Dear thread. You've been JACKED!!!
  19. #19 Re: To build bottom end, or not to build bottom end?
    May 2008
    Schuyler, NE
    So, wait...why are you rebuilding your motor? The way I'm understanding this thread, it's running fine. Correct?
    I'm guessing its because it wants to put his XP cam in it so he wants to rebuild it first? Really not sure.
    04 Comp G.
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  3. bottom end
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 11:01 AM
