Thread: 99 gtp misfire #1 under load /in boost Heelp!!
Results 1 to 13 of 13
  1. #1 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    93 octane, vac at map senser is normal and boost gauge read the same but will double check all vac lines for leaks
    Thanks
  2. #2 Re: 99 gtp misfire #1 under load /in boost Heelp!!
    Feb 2009
    North Adams, Ma
    ok ive had no luck with anything replaced vac lines with "t"s lower intake manifold gaskets... still no change will throw a p0300 has 120 psi compression..... scratching my head?
    any other advice?
    thanks
  1. cutting out under load and boost!!
    By Blowblackorgetback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 10:08 AM
  2. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  3. Misfire when car warms up and no boost
    By jjuver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 06:26 AM
  4. Misfire when getting boost on 99 gtp help!!
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 11-21-2010, 10:20 PM
  5. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
