Thread: 3.8 series II sc blows smoke with rev
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: 3.8 series II sc blows smoke with rev
    Oklahoma
    I cant say what tools you would need. Ive bought the seals but have never installed them.
  2. #2 Re: 3.8 series II sc blows smoke with rev
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    i finally decided to get off my lazy ass and do the valve stem seals. it wasnt too bad, mainly the rear was frustrating but that was to be expected. so i did the seals and it still smokes just as much. i decided to do a compression test. 2 cylinders had about 150-175 psi. the other 4 cylinders were about 75-100 psi YAY!!
    COMP G
  3. #3 Re: 3.8 series II sc blows smoke with rev
    Donating Users blowfishRus6's Avatar
    g.a.
    what does that mean? what causes this? and dont flame for the lack of knowledge
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: 3.8 series II sc blows smoke with rev
    Feb 2008
    I smell worn rings seals.
    The low pressure can be caused by bad ring seals, slightly bent/stretched valves, or other valvetrain issues that can keep the valves from closing all the way.
  5. #5 Re: 3.8 series II sc blows smoke with rev
    Jul 2008
    Poteau Oklahoma
    looks like rings to me.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  6. #6 Re: 3.8 series II sc blows smoke with rev
    g.a.
    ahhhh. good to know
    its slow.
  7. #7 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Vallejo,Ca
    indeed, i think the thrasher s/c pulley caused premature wear on the engine , the person i bought the car from had it on there , and the damn pulley is real small
    COMP G
  8. #8 Re: 3.8 series II sc blows smoke with rev
    Feb 2008
    Hmmm smaller pulley of unknown size, who knows what was done to it before you got it and how it was treated. It's possible that someone laid a pulley on it and didn't tune it. Have you done a compression test?? I wouldn't be surprised if you have a cracked or chipped piston.
  9. #9 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Blown97 View Post
    refer to post #22
    COMP G
  10. #10 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Chillin at the Beach , VA
    Like to see the inside of that motor to see what damage the previous owner has done.
  11. #11 Re: 3.8 series II sc blows smoke with rev
    TDCRacing
    Guest
    When doing the compression test you did turn each cylinder over for the same amount of time correct? Usually for about 5 cranks per cylinder.
  12. #12 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by TDCRacing View Post
    i cranked the engine over 10 seconds per cylinder
    COMP G
  13. #13 Re: 3.8 series II sc blows smoke with rev
    NE Ohio
    int eh videos you posted, im hearing a clicking that increases with engine speed..some type of valvetrain noise thats too loud.
    the previous owner probabaly messed somethign up there.
    if you want to, since you seem to know what youre doing, pull the sc belt off, take a string, wrap it around the pulley in one of the grooves, measure the length of string it takes to go around the pulley one time, divde by 3.14 and theres your pulley size.
  14. #14 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by kyle99gtp View Post
    yeah, it has a bad lifter tick on cold start, when warm its quiet, only when you open up the throttle does it return. somebody hot rodded the hell out of the car and didnt care to keep it maintained in the process. im not mad about though. i was looking for an engine to rebuild lol
    and your pulley size method is good to know, i will try that later
    COMP G
  15. #15 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    In the vid, looks like it may be a 3 or 3.2 pulley. possibly a 3.4. Looks a hair smaller than mine though.
  16. #16 Re: 3.8 series II sc blows smoke with rev
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by BADAZGTP View Post
    yeah its a tiny, im thinking its a 3
    COMP G
  17. #17 Re: 3.8 series II sc blows smoke with rev
    NE Ohio
    glad to be of assistance
  1. Replies: 6
    Last Post: 10-11-2008, 09:30 PM
  2. Autometer Z series are fogging up
    By 99prixgt in forum Off Topic Discussion
    Last Post: 09-30-2008, 06:16 AM
  3. 3800 Series III 1/4 Mile
    By gp04 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 03:40 PM
  4. Interior Light Fuse Blows....
    By hester21289 in forum General Tech Discussion
    Last Post: 03-12-2008, 08:02 PM
  5. Great Article in POCI's 'Smoke Signals'
    By SD GTP in forum Off Topic Discussion
    Last Post: 02-05-2008, 05:17 PM
