Thread: 97 GTP Leaking Coolant after turning engine off?
Results 1 to 8 of 8
  1. #1 97 GTP Leaking Coolant after turning engine off?
    Quincy, MA
    So I just replaced my coolant elbow which was leaking a few weeks ago. Got the car back and after a few days it started leaking coolant after I turn the engine off. Looks like it's coming from the right bottom side of the radiator as if you are facing the engine. Only shows leakage when I turn the engine off. Nothing when parked after driving and leaving the engine running. Any ideas? Thanks.
  2. #2 Re: 97 GTP Leaking Coolant after turning engine off?
    Quincy, MA
    Oh and I don't appear to be overheating at all. I would say it's taking longer than normal for the engine to cool down but it never goes above halfway on the temperature gauge while driving.
  3. #3 Re: 97 GTP Leaking Coolant after turning engine off?
    buy a pressure tester and make it leak, so you can pin point where its coming from.
  4. #4 Re: 97 GTP Leaking Coolant after turning engine off?
    The side tanks on our radiators are plastic. They expand and contract each time you heat up the car. This can cause the plastic to crack...but it only leaks when expanded. Typically we notice if when the engine is turned off because heat and excess pressure.
  5. #5 Re: 97 GTP Leaking Coolant after turning engine off?
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    ^ yes thats where mine is leaking right now. probably yours too
  6. #6 Re: 97 GTP Leaking Coolant after turning engine off?
    Quincy, MA
    Is there a fix for this or is it going to require a new radiator?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    If tge radiator is leaking, replace it.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  8. #8 Re: 97 GTP Leaking Coolant after turning engine off?
    The endcap could be replaced if you can find someone that still fixes radiators. However you are more likely to get one off the internet in a day for a reasonable price.
  1. Leaking coolant in my 00 gt
    By GPrixGT00 in forum General Tech Discussion
    Last Post: 06-03-2011, 12:01 PM
  2. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
  3. Think im leaking coolant
    By blackgpgt in forum General Tech Discussion
    Last Post: 02-14-2010, 03:56 PM
  4. Leaking Coolant
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-23-2009, 06:03 PM
  5. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
