Thread: this setup
Results 1 to 13 of 13
  1. #1 this setup
    Donating Users
    Plainfield, IL
    so these are my plans......3.4" pulley, downpipe with high flow cat and u-bend delete, NGK T6 plugs, FWI with K&N, ZZP cat back exhaust.....how much wheel horse can i expect and how much of a difference will i notice?
  2. #2 Re: this setup
    Oklahoma
    Moved to the correct section!
  3. #3 Re: this setup
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Quote Originally Posted by iamwhutiam003 View Post
    With that pulley your going to have Knock, it will drop timing and lower your hp making your car slower then you would like. If you plan on a pulley drop you need a scanner, or more preferable a tuner. Mod until you have 0* of kr and then you can start dropping pulleys. Also most people start with a 3.5" [down from the stock 3.8"].
    If you get the zzp cat back exhaust it deletes the ubend so you dont need the u bend delete also.
    On top of that i would recommend autolite 104 spark plugs, they may have to be replaced a bit more then ngk but our cars highly prefer autolite copper plugs.
    With all that minus the pulley you will be making around 190 to the wheels. [this is an estimate no way to know for sure without a dyno]
    Look at my second post on this thread for beginning modification recommendations.
    http://www.grandprixforums.net/f18/h...ions-6957.html
    2006 Grand Prix GXP
  4. #4 Re: this setup
    Donating Users
    W-S, NC
    I would be think a lil higher than the 190hp range. ZZP dyno'ed one in full stock form that put down 190 to the wheels.
  5. #5 Re: this setup
    Banned
    Wichita Falls, Texas
    With a downpipe and or u-bend delete/ZZP cat back, along with Autolite 104's and a FWI you will have no problem running a 3.4 pulley.
  6. #6 Re: this setup
    Donating Users
    W-S, NC
    Quote Originally Posted by Street Wolf View Post
    I think it wouldnt hurt him to run a pcm to make it all come together. Just remember to scan scan scan!
  7. #7 Re: this setup
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by DnaProdigy View Post
    Acually it doesn't. It goes cat, ubend, then the flange to the catback.
    Yes he will be able to run it, but not safely. Some people are having kr problems with the 3.4" pulley even with headers. Yes every car is different, but there is only a select few factory freaks that would be able to run that setup with little to no KR nowadays.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  8. #8 Re: this setup
    Jul 2008
    New York
    Quote Originally Posted by Smokin2000gtp View Post
    Acually it doesn't.
    Your very right for some reason i though the u-bend delete came with he zzp exhaust kit.
    Don't drop pulley sizes. IF you want to in all reality you should either A) Have a scanner, make sure you have no Kr and then only drop a size at a time. Or B) have a tuner so you can properly tune your vehicle to eliminate the Kr.
    2006 Grand Prix GXP
  9. #9 Re: this setup
    Donating Users blowfishRus6's Avatar
    g.a.
    with a horsepower calculater, giving my weight and trap speed, said i was putting down 214hp. of course that doesent calculate for tourqe or gears tho.
    if you got a powerlog to go along with those mods, because the front manifold is VERY restricetive, you might be able to run the 3.4 safely with a tuned pcm. but i would scan first. any KR sucks and just makes you slower. but if your running KR free with the 3.4 i dont see a problem, if your a decent driver, doing high 13's in the 1/4. hell im gonna try and hit low 14's with intake and headers. gotta love gen V blower and 3.29 gears
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  10. #10 Re: this setup
    TDCRacing
    Guest
    sound like a good setup to me, If your looking for a fenderwell intake let me know. I can hook you up with the best one out there....at the price thats cheaper than all the rest on the market.
    If you go any further wouldnt be a bad ideah to get a scan gauge.
  11. #11 Re: this setup
    Donating Users
    Plainfield, IL
    if all this gets done its all gonna be done and tuned by ZZP themselves so there wont be KR they will tune it after the mods....but all that and to not be over 200 HP would piss me off i was expecting at least 220..... lol
  12. #12 Re: this setup
    g.a.
    you should be near if not a little more than 220 with those mods.
    its slow.
  13. #13 Re: this setup
    g.a.
    remember hp dont win races. torque does with those mods you could be around 280tq
    its slow.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. New GTP badging setup
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 10-14-2008, 07:03 PM
  3. Setup Opinions
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2008, 12:41 AM
  4. current setup
    By crshoveride in forum Audio, Security & Visual Electronics
    Last Post: 09-05-2008, 08:40 AM
  5. Current setup
    By jarleifv in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2008, 07:27 PM
