Thread: LTFT Question.
Results 1 to 3 of 3
  1. #1 LTFT Question.
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Sup,
    Just got around driving my car a bit, it's been good in the ltft city driving in the past week, but it always had a buzzed up fuel cell (Low Load condition one, when barely pressing on the gas, let's call it LLC).
    First Question : What might cause the LLC cell to crawl to 16.4, when, trigering it by lightly pressing the gas, let say, on highway, going down slight slope, or city driving when trying to keep a steady pace.
    Second Question : Today something creeped me out, because it never did it, when letting go on the gas in D, it would jump to 16.4, then when giving it gas it would go back into normal -3.9%.
    Then when in Park, it would get steady at -3.9%.
    Other infos, vacuum was apparently at 20.5in/hg in park, which sounds fine by me, had my car checked for leaks in the past already, gonna re-check it later this week with my mech. All vac lines are new, MAP is new, and stuff.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: LTFT Question.
    Well when you step on the gas and let off of go down a hill the car cuts fuel because its not needed and can cause the jump in numbers you are seeing.
    Having 3.9 at idle is fine
  3. #3 Re: LTFT Question.
    Québec
    Well nothing to worry about ltft going to 16.4 when, under either very low load? (Like cruising down a micro slope on highway, or just letting go of the gas?)
    Never saw a lean condition CEL either.
    Because all I know is that once I step on the gas, it goes in the negatives, always.
  1. Ltft @ 16?
    By rperry435 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2012, 09:53 PM
  2. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  3. LTFT and O2 problems
    By ASCStinger in forum PCM Tuning
    Last Post: 10-13-2010, 05:38 PM
  4. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  5. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
