From what I have read the xpz cam is really easy to blow up your car if you don't tune it right. And I am pretty sure with either of those cams you need a double roller. Stock bottom end will hold to whatever you throw at, I thought someone said that zzp used a stock bottom end in there TTGT. Just heads cam and stuff. At that point I would also upgrade fuel injectors.
