Thread: Cooling Fans Problem
Results 1 to 6 of 6
  1. #1 Cooling Fans Problem
    Sep 2012
    St Louis Missouri
    Ok so after i changed to open cone intake my cooling fans stay on all the time so my engine never heats up much at all.
    Im guessing its either because 1: My pcm is broken cause its just sitting there under the 9" Spectre cone on the bottom of where old intake used to be, or 2: Because the sensor that was in the old intake is ziptied in the engine bay and not inside the tubing from the intake to the throttle body.
    Which do you think.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Obvious answer. Clearly you need to drill a hole and put it where it belongs.. not sure if that has anything to do with your fans though.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Cooling Fans Problem
    Sep 2012
    St Louis Missouri
    Then it's not obvious.
  4. #4 Re: Cooling Fans Problem
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    prob broke the wire that goes to the temp sensor does ur temp gauge move at all?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Cooling Fans Problem
    Sep 2012
    St Louis Missouri
    it usually stays really low. like 1-3 notches above 160. but it does move up to that.
  6. #6 Re: Cooling Fans Problem
    Sep 2012
    St Louis Missouri
    Actually with the possibility of it being the thermostat im going to wait til i do the lim replacement and see if it continues.
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  3. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  4. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
