Thread: Replaced battery now running poorly.
Results 1 to 5 of 5
  1. #1 Replaced battery now running poorly.
    Sep 2012
    hamper
    Hey guys heres anouther problem Ive having with this heap....lol
    I got a brand new battery for the bad boy and went to start it and now the car seems to idle very poorly, is this another common problem with the GTP? this car is just getting on my nerves now... lol seems like you always need a Straw to get something to work either pull your key out you need a straw or to get my windows to roll down properly you need a straw, my room mates are getting upset because I keep taking straws...................
    - thank you, Mel - 2002 Grand Prix GTP
  2. #2 Re: Replaced battery now running poorly.
    GTP Level Member
    springfield IL
    Correct battery..?? Dont think a bad alt would cause that, at least from my experiences
  3. #3 Re: Replaced battery now running poorly.
    Sep 2012
    hamper
    I bought it a ACdelco... so it should work.
  4. #4 Re: Replaced battery now running poorly.
    Did you clean the connections really good? also make sure the terminals are tight. And what do you mean by straws getting stuff to work?
  5. #5 Re: Replaced battery now running poorly.
    St. Louis
    How long was the battery disconnected? Most likely it cleared out the ECM and it needs to relearn everything. Take it for a normal drive (not romping on it) for about 15-20 min. and then see if it runs better. If it does, then you can take it out and run it harder. I usually take mine on a road that varies the speed limit so it can get reading at different speeds/throttle inputs to give it a better idea of what's going on.
  1. Was noisey now runs poorly
    By jsaylor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2012, 12:10 PM
  2. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  3. Replies: 1
    Last Post: 01-17-2012, 09:24 PM
  4. Intake Replaced, Still Running Lean
    By grandamle91 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 12:30 AM
  5. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
