Thread: Engine temperature
Results 1 to 3 of 3
  1. #1 Engine temperature
    Oct 2012
    London ON
    Recently bought a Grand Prix gtp and noticed the temperature gauge goes to half way 100 degrees when I stop and goes back to normal when I start driving but sometimes when it's cold out you can see steam comin from under the hood, doesn't happen all the time hit the engine is really hot I pull the oil dipstick and its smokin it's so hot. Any ideas what that might be. Also is it normal for the temperature to jump up and down all the time?
  2. #2 Re: Engine temperature
    Might be time for a coolant flush with a new thermostat and then bleed the cooling system of air to make sure it wont overheat.
  3. #3 Re: Engine temperature
    Oct 2012
    London ON
    Yea flushed it last night now it's basically staying around the. 1/4 mark goes a little over but not that much
  1. Temperature controls from 98 to 97
    By chuckbattams in forum General Tech Discussion
    Last Post: 09-29-2012, 12:56 PM
  2. Temperature is all over
    By aray590 in forum General Tech Discussion
    Last Post: 03-13-2012, 10:01 PM
  3. Very weird engine temperature behavior...
    By T0pwater in forum General Tech Discussion
    Last Post: 04-13-2011, 01:44 PM
  4. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  5. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
