Thread: p1362
Results 1 to 9 of 9
Threaded View
  1. #1 p1362
    gardner,mass
    My car was running off today( kind of bogging and skipping) so i stopped at my work to read the code. P1362 said crank position sensor low voltage i think. Anyway anyone have any clues to the problem? But under the code it said pending. I also had p0403 and p0405 but i have no cat or egr so ya obviously
    Edit: this is what i googled
    P1362
    Description
    BY-PASS CIRCUIT SHORTED
    Ignition Control Module (ICM) sends signals that the PCM
    requires for fuel control and spark advance calculations. At the start
    of engine crank, the ICM control spark advance (by-*** mode). When the
    second 3X reference pulse is recognized by the PCM, PCM applies 5
    volts to by-pass circuit, commanding ICM to switch spark advance to
    PCM control (IC mode).
    If PCM detects a short to voltage in by-*** circuit, DTC will
    set. A short to ground in the IC circuit or by-pass circuit will cause
    both DTCs P1361 and P1362 to set. Engine will start and run in by-pass
    mode timing.
    Symptoms
    You likely won't notice any drivability problems.
    Causes
    • PCM detects a short to voltage in by-pass circuit.
    Solutions
    • Locate and repair short in by-pass circuit.
    • Replace IC control module.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  1. p1361 B and p1362 B codes came up on the way home tonight?
    By natejames99gtp in forum General Tech Discussion
    Last Post: 07-29-2012, 10:38 PM
