I finnaly have the SC belt on my car, and have boost...... And tons of KR, so I'm in need of a lot of tuning time... but at lease I heard the whine![]()
Congrats!! First i would drop to colder plugs. Autolite 104's seem to be the best bet. Then get a 180* t-stat. If your still getting significant Kr try opening up the exhaust a bit more, either headers or plog, and u-bend delete.
How much Kr are you getting btw?
Edit: Oh i noticed you have a tuner also, im kind of curious how much you can eliminate with the tuner alone.
2.5 dp and wizardair, and lowered timing should take care of KR on a 3.8 pulley, but my vac leak is throwing all my fueling off..... maybe I need to scale my MAF more...... Ive got a lot of tuning to do, and a vac leak to findalso, you need to have some more work that that car to run alright without knocking a lot. get headers, a plog, rockers, a bigger downpipe..you need something.......
180* stat, autolite 103's (I know too cold)....It is in the tune, I am way lean when the KR hits... I need to adjust MAf and fueling ( I have a ported 98 maf)
Do you at least have a DP and Plog or something?
Auto lite 104? Do u even get a diffrence with em?
Im running stock AC delcos on em. They werent cheap eather,
id go to the hotter plugs. the 104s should be where you want them at your mod level.
^^^Yeah, if I can only find time.....Also upgrading to TR6IX plugs this week, since my A103 are way too cold, and I cannot stand the idle that they give me
