Thread: Need E85 advice please
Results 1 to 20 of 25
  1. #1 Need E85 advice please
    GTP Level Member Ultra440's Avatar
    Ohio
    Someone give me the low down. I know I need bigger injectors, 60 lbs are just as good as the 42s.
    Do I go with a 3.0" pulley? 3.25"? I'd rather be on the conservative side if need be.
    My stock fuel pump will keep up or no? Is a walpro absolutely necessary?
    I have a stock cam/rockers as well. Will they hold up?
    This is my DD and I'm still paying for it so I really don't want to break anything but I've been wanting to do this for a whole now.
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  2. #2 Re: Need E85 advice please
    This info is out there, somewhere.
    Ohio
    Got my questions answered with the exception of the stock cam/rockers durability. Got an iffy answer on that one.
  4. #4 Re: Need E85 advice please
    Cam is billet steel.
    It ain't going anywhere.
    Rockers will be fine, often used in many very aggressive setups.
    The needle bearings will eventually wear out and have excessive side to side play, but that happens no matter what you do.
    It seems stock rockers are the ideal solution for just about any setup with a cam.
  5. #5 Re: Need E85 advice please
    Quote Originally Posted by Ultra440 View Post
    they do not relate to each other in the sense that you are worried about... dont forget your tune homes...
  6. #6 Re: Need E85 advice please
    Out West
    start with 3.4
    headers?
    Whine with your Cheese?
  7. #7 Re: Need E85 advice please
    3.4" on E85?
    luel.
    Who wants a 4.8" on a stock L67 car. Solid comparison.
  8. #8 Re: Need E85 advice please
    Out West
    timing > pulley, didn't you say that yourself?
  9. #9 Re: Need E85 advice please
    Timing > Pulley when you make more than 2 psi, guyguy.
  10. #10 Re: Need E85 advice please
    Banned
    Jun 2012
    Sacramento CA
    You would be pushing your luck below a 3.2. Make sure you have your AFR dialed in, E85 blends change with the wind.
    Good luck!
  11. #11 Re: Need E85 advice please
    Jan 1970
    Maquoketa, Iowa
    You need to own a tuner, or have a E85 station readily available and then say goodbye to road trips. I would also get a wideband.
  12. #12 Re: Need E85 advice please
    Out West
    Quote Originally Posted by fry626 View Post
    Good luck!
    This because crappy 3800 heads.
    Quote Originally Posted by FoSHO99 View Post
    So, HPT, WBo2, E85 and some jerry cans in the trunk, and get a second car for traveling.
    Ohio
    My girlfriend has a slightly better mpg in her Acura so we usually take that anyways. BUT my tuning guy said just get another PCM and I can have one tuned for gas on my 3.5 and one tuned for e85 with a small pulley. Keep the PCM in my trunk just in case.
    I make frequent trips around Ohio and I've already looked into e85 stations around my destinations and I'm good.
    He also said if he can get an a/f around .75 the 3" will work but to bring a 3.2 JIC. I may just do the 3.2 to be on the safe side. Maybe a 3.1.
    Ohio
    As far as the widebands, I don't know too much about them. They go into an o2 bung and read out on a gauge in the car? How much $ do these typically go for?
  15. #15 Re: Need E85 advice please
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Depends on if you want crap or something worth getting. If you want a good one like 150-300 dollars depending on brand and if you buy used or new
    I went NA when a whore left -$300 in my bank account.
    Ohio
    Does the aeroforce gauge have wideband inputs?
    Or is it a totally seperate gauge?
    You want to google ntk afx vs aem.
  18. #18 Re: Need E85 advice please
    aem ftw
  19. #19 Re: Need E85 advice please
    If you google the term, AEM FTL.
    NTK AFK or bust.
  20. #20 Re: Need E85 advice please
    Out West
    I wouldn't go lower than a 3.2 there, period.
  1. Need some advice for GPF...
    By silvermistgt2002 in forum Off Topic Discussion
    Last Post: 10-05-2012, 11:13 AM
  2. Any advice?
    By hoagieman26 in forum Visual/Body Modifications
    Last Post: 10-16-2011, 09:00 AM
  3. Advice of anything else i can do while i have the sc off
    By DukesGTP in forum Off Topic Discussion
    Last Post: 01-01-2011, 07:00 PM
  4. Need Advice
    By Amberella06 in forum Introductions/Noob Questions
    Last Post: 07-26-2010, 10:01 AM
  5. Need advice on dhp 1.0 pcm
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2009, 09:46 PM
