Thread: Cooling fans stuck on. Help
Results 1 to 7 of 7
  1. #1 Cooling fans stuck on. Help
    seattle
    Hello all. I have a 2000 gtp that the cooling fans come on at start up and never shut off. Coolant level is at the top and the ac is shut off. At this point I have just pulled the master fuse as it is not hot enough to worry about overheating. Another little piece of information, even with the fuse for the fans pulled the car has been running cooler than it ever has before(around 170). Any ideas? Thanks for any help
  2. #2 Re: Cooling fans stuck on. Help
    St. Louis
    Sounds like maybe the relay for the fans it bad. Maybe swap it with another one under the hood and and see if the fans work properly.
  3. #3 Re: Cooling fans stuck on. Help
    could be a bad coolant temp sensor as well.
  4. #4 Re: Cooling fans stuck on. Help
    If the car is running much cooler. The PCM might think the ECT is bad and kick on the fans as a fail safe. Any codes?
  5. #5 Re: Cooling fans stuck on. Help
    seattle
    Thanks in advance to all who have replied. No codes thrown. Sounds like the ect is where all the people seem to be pointing. Where is the sensor located and any tips or tricks on replacing would be great. I think this is going to be my first course of action. Thanks guys.
  6. #6 Re: Cooling fans stuck on. Help
    It is located in the LIM right below where the radiator hose goes into it.
  7. #7 Re: Cooling fans stuck on. Help
    and..it can suck to replace as the engine mount bracket keeps you from having good access. Drain the coolant ahead of time.. There's quite a bit in the upper end of the motor.
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  3. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  4. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
