Thread: Reduced Engine Power - PO1125
Results 1 to 7 of 7
  1. #1 Reduced Engine Power - PO1125
    Aug 2012
    United States
    I have a 04 GTP with 106K miles. At 87K I had to replace the motor due to a bottom end problem and have 66K on the new motor. The new motor came online fine with no issues and has performed well. Recently, if I get on her, passing, merging, etc. I get the DING DING and "Reduced Engine Power". Throws a PO1125 code. I can shut it down, wait a minute or two and it starts right up and the check light goes out. The car runs fine (other than bad gas mileage that I haven 't figured out yet), and no other codes or problems. I can even accelerate fairly quickly without any problems. Only when I ROMP on it, it dies at about 3200 RPM.
    I suspect its a throttle pos sensor or someting, but its going to take someone better than me to tell me how to test, fix this. Many thanks in advance for your help on this one.
    What's the point of having a GTP if it croaks at 3200 RPMs?
  2. #2 Re: Reduced Engine Power - PO1125
    P01125?
  3. #3 Re: Reduced Engine Power - PO1125
    St. Louis
    Sounds like an issue with the accel. pedal position sensor. Part of the pedal assembly.
  4. #4 Re: Reduced Engine Power - PO1125
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    The control module provides the APP sensors a 5-volt reference circuit and a low reference circuit. The APP sensors then provide the control module signal voltages proportional to pedal movement. The APP sensor 1 signal voltage is low at rest and increases as the pedal is depressed. The APP sensor 2 signal voltage is also low at rest and increases as the pedal is depressed. One APP sensor DTC will not cause the Reduced Engine Power message to be displayed. Two APP sensor DTCs for the same sensor also will not cause the Reduced Engine Power message to be displayed. However, if two or more DTCs are set involving more than one APP sensor, DTC P1125 will set.
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Reduced Engine Power - PO1125
    Apr 2009
    Elkhart
    The accelerator pedal position (APP) sensor 1 and APP sensor 2 are potentiometer type sensors, each with the following circuits:A 5-volt reference circuit A low reference circuit A signal circuit
  6. #6 Re: Reduced Engine Power - PO1125
    Apr 2009
    Elkhart
    Conditions for Running the DTCDTCs P0606, P1518, P2108 are not set. The ignition is ON. The communications between the throttle actuator control (TAC) module and the powertrain control module (PCM) must be valid. Conditions for Setting the DTCTwo APP sensors are out of range or both APP sensors disagree with each other.Action Taken When the DTC SetsThe control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails. The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame and/or the Failure Records. The control module commands the TAC system to operate in the Reduced Engine Power mode. A message center or an indicator displays Reduced Engine Power. Under certain conditions the control module commands the engine
  7. #7 Re: Reduced Engine Power - PO1125
    Apr 2009
    Elkhart
    thats off of shopkey5 under code p1125
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  3. Reduced engine power. Help!
    By Jeremy1279 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 06:54 PM
  4. Reduced Engine Power???
    By 05gtPEACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2010, 06:21 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
