Thread: Developed a rod knock in 01 GTP, which short blocks or complete engines can be used?
Results 1 to 6 of 6
  1. #1 Developed a rod knock in 01 GTP, which short blocks or complete engines can be used?
    Aug 2012
    Cedar Rapids, Iowa
    I am searching for a replacement engine for my GTP, I bought this car not too long ago "maybe couple months" and dumped alot of money into it.. After doing intake gaskets it developed a rod knock. anyway I need a engine or a shortblock to swap my upper end onto.
    Can I use a NA short block? If so what years and models?
    Should I just stick to a complete GTP engine and drop it in?
    Just curious the best way to go about this, thanks
  2. #2 Re: Developed a rod knock in 01 GTP, which short blocks or complete engines can be us
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    if you use a na short block you would have to tune as it would be considered a topswap.. it would be able to run on stock gtp computer but it wouldnt be completely safe
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Developed a rod knock in 01 GTP, which short blocks or complete engines can be us
    new britain, ct
    look for a gtp block or complete engine.
    07 Black GXP.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I just got a new motor myself.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Developed a rod knock in 01 GTP, which short blocks or complete engines can be us
    Aug 2012
    Cedar Rapids, Iowa
    So Im guessing at minimum the pistons are different between the 2?
  6. #6 Re: Developed a rod knock in 01 GTP, which short blocks or complete engines can be us
    Rods and pistons and heads are different between NA and SC.
    Just find a SC block and swap it in.
  1. Developed a blinking oil pressure guage.
    By spider4 in forum General Tech Discussion
    Last Post: 02-04-2012, 09:35 PM
  2. 'Short Shifter' Complete
    By Curt7 in forum Members Rides
    Last Post: 09-05-2011, 02:29 PM
  3. Can L36 short blocks be used in an L67??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2010, 07:54 PM
