Thread: Temp fluctuates a lot city driving
Results 1 to 4 of 4
hunter_alexander Temp fluctuates a lot city... 09-16-2012, 07:31 PM
Fivefingerdeathpunch Re: Temp fluctuates a lot... 09-16-2012, 07:34 PM
hunter_alexander Re: Temp fluctuates a lot... 09-18-2012, 07:18 PM
Timing Re: Temp fluctuates a lot... 09-18-2012, 08:46 PM
  1. #1 Temp fluctuates a lot city driving
    SE Level Member hunter_alexander's Avatar
    Erie Pa.
    OK, so I have replaced the LIM, all hoses, 190* tstat etc. The coolant system has been bled, everything done correctly.
    Car has 170k miles on it but runs fantastic otherwise.
    Since then (~6k miles) I have noticed that my temp fluctuates a lot. From 180* to above 220*, sometimes higher, depending on outside temp. That is sitting in traffic. As soon as I start moving again it goes down.
    Now, I did look and my fans are working, but I think only on low, as in spinning, but not fast. When the temp is up there, shouldnt they kick on high?
    Could my fan relay be bad? Where is it located? Easy to replace?
    Also, getting a squeak squeak like a vaccum pump sound under the dash. Related? What is that sound.
    Thanks for the help.
    Craig
    If all else fails, throw money at it..... that'll fix it.
    Check out my website here: http://craig.beesky.com/1987_olds_cutlass.htm
  2. #2 Re: Temp fluctuates a lot city driving
    Cooling system is fully bleed of all air?
  3. #3 Re: Temp fluctuates a lot city driving
    Erie Pa.
    As far as I can tell yes. I have bled it multiple times, but not sure how to verify that there are no trapped pockets.
  4. #4 Re: Temp fluctuates a lot city driving
    gardner,mass
    put your car on high heat and then open the bleed valve and let it go untill it comes out in a steady stream close it and shut off the car and let cool then fill the radiator cap to top close and repeat drive for a few days and it should bleed the rest itself, then make sure the reserve tank is full to the cold line when cold and you should be all set
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  1. Replies: 7
    Last Post: 06-25-2012, 03:34 PM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. Temperature gauge fluctuates
    By wagatlng in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2010, 01:05 PM
  4. DIC Voltmeter fluctuates between 14.5v and 12.6v
    By unclediesel in forum General Tech Discussion
    Last Post: 08-05-2010, 09:29 PM
  5. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
