put your car on high heat and then open the bleed valve and let it go untill it comes out in a steady stream close it and shut off the car and let cool then fill the radiator cap to top close and repeat drive for a few days and it should bleed the rest itself, then make sure the reserve tank is full to the cold line when cold and you should be all set
