OK, so I have replaced the LIM, all hoses, 190* tstat etc. The coolant system has been bled, everything done correctly.
Car has 170k miles on it but runs fantastic otherwise.
Since then (~6k miles) I have noticed that my temp fluctuates a lot. From 180* to above 220*, sometimes higher, depending on outside temp. That is sitting in traffic. As soon as I start moving again it goes down.
Now, I did look and my fans are working, but I think only on low, as in spinning, but not fast. When the temp is up there, shouldnt they kick on high?
Could my fan relay be bad? Where is it located? Easy to replace?
Also, getting a squeak squeak like a vaccum pump sound under the dash. Related? What is that sound.
Thanks for the help.
Craig
