Thread: No coolant from bleeder?
Results 1 to 6 of 6
  1. #1 No coolant from bleeder?
    GTP Level Member Ultra440's Avatar
    Ohio
    Any clues? There's no air or liquid coming out. I pulled my tensioner to replace the elbows and then topped off the coolant. Let it run mostly bubble free under the rad cap, topped off again and now I'm not getting anything from the bleeder.
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
    Quincy, Mass
    Is the coolant up to temp yet? It won't come out until the t stat opens if I remember right. Or the bleeder is clogged with shmegma.
    No more GP 04 Impala SS Indy:
  3. #3 Re: No coolant from bleeder?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    what he said
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: No coolant from bleeder?
    No answer so he probably went out and got it up to temp and bled it just fine lol
  5. #5 Re: No coolant from bleeder?
    Top off the coolant in the LIM first.
    Then the rad and bleed it.
    Ohio
    Sorry, was at football game all day. I had the bleeder screw completely off and nothing. It was up to temp. Check it again in the morning, been a long day. Drove it to the game and coolant temp was right on point, coolant levels looked fine in rad and overflow.
  1. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  2. Brake Line Bleeder size?
    By PlayingMechanic in forum General Tech Discussion
    Last Post: 03-01-2012, 01:07 AM
  3. Need help with broken Bleeder screw when replacing thermostat!!!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 02-15-2012, 09:16 AM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
