Thread: xp cam build list
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 xp cam build list
    GTP Level Member joe0813's Avatar
    Boston, MA
    well i have received everthing for my cam install.... XP cam, modified retainers, double rollermaster timing chain, 705 push rods, 875 lifters, 4 lay head gasket, valve cover, intake and supercharger gaskets and arp head studs. Before i pull my motor to start the build am i missing anything? or something that i should buy because a part normally breaks coming out... like those plastic coolant elbows.
    thanks guys
  2. #2 Re: xp cam build list
    May 2012
    United States
    just use felpros for head gaskets. they are 16 dollars a piece at autozone. stock lifters work the best.
    2011 10.82@126 fastest GenV M90 car
    http://www.youtube.com/watch?v=4gyLo...&feature=g-upl
  3. #3 Re: xp cam build list
    May 2011
    Kansas City
    they now make aluminum coolant elbows....dorman is the manufacturer...aaaand im also gonna suggest new front cover gasket
    Reptile Tune (SOLD)
  4. #4 Re: xp cam build list
    Jan 2012
    Philadelphia
    did you get valve springs?
  5. #5 Re: xp cam build list
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Timing chain cover gasket(s).
  6. #6 Re: xp cam build list
    dont you have to machine the front cover to run the double roller and machine the crank gear or something like that.
  7. #7 Re: xp cam build list
    Jan 2012
    Philadelphia
    you can buy the machined front cover from ZZP, not sure about the crank gear though
  8. #8 Re: xp cam build list
    Banned
    Sioux Falls, SD
    Im guessing your going to pull the motor and while you have it out change the oil pan gasket
    If you going to spend the time and money on the double chain DONT do the machined cover or double gasket spend the little extra (Cost me $30) To have the chafer of the crank grear milled. I spun a rod bearing on my motor so i had to sawp all my parts to a new block and i had about 2-3K on for mileage and i had no wear marks anywhere on the cover or anything.
    Before:
    After:
    Assembly Lube I know its common sense but just a reminder
    Get reuseable rocker bolts
    Depending on your milage get a new oil pump Like $40 from O'Reillys
    Switch to Green coolant if you already havent (Make sure to flush Heater core and Rad)
    You can get the GM gasket set (Includes Alluminum LIM gaskets, Valve Cover Gaskets, Head Gaskets) for like $119. I always use copper spray on my head gaskets
    Get a set of Headers if you dont have any.
    Also do you have someone to tune the car?
  9. #9 Re: xp cam build list
    Boston, MA
    I got 130 springs. Zzp told me I could remove the balance shaft gear and the double timing chain would fit. I will order a new front cover gasket tomorrow. There is a place in the next town over that tunes cars so I'm going to see if they have experience with the 3800.
  10. #10 Re: xp cam build list
    Removing the balance shaft has nothing to do with the double roller fitting where it matters.
    The crank gear needs to be machined and chamfered to match stock.
  11. #11 Re: xp cam build list
    lol lifters.
    those things are apparently pretty damn noisy.
    run ls7s.
    ZZP *****ed about the JP chains yet won't tell you their rollmaster sets also dont fit properly.
    How honest of them.
  12. #12 Re: xp cam build list
    Boston, MA
    So I have to remove the balance shaft gear and machine the crank gear too??
  13. #13 Re: xp cam build list
    To run the double roller yeah.
    And you have to drill and tap the oil port that lubes the balance shaft and block it off...to do it right that is.
  14. #14 Re: xp cam build list
    May 2011
    Kansas City
    Quote Originally Posted by blueguy91 View Post
    who does things right on this forum? Lol
    Reptile Tune (SOLD)
  15. #15 Re: xp cam build list
    Well I never did.
    Wasting money on building a higher HP FWD platform is silly
  16. #16 Re: xp cam build list
    May 2011
    Kansas City
    thats true...but it is something to do when you get bored lol
    Reptile Tune (SOLD)
  17. #17 Re: xp cam build list
    Boston, MA
    So what exactly tell the machine shop to machine the crank gear? What a pain in the ass
    Ohio
    Yes the inside chamfer needs to match the stock gear...
  19. #19 Re: xp cam build list
    And so does the height...hence the machined surface.
  20. #20 Re: xp cam build list
    Banned
    Sioux Falls, SD
    Quote Originally Posted by joe0813 View Post
    Look at the pictures i posted
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. Taz's Offical Summer/Fall build list.
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 01:23 PM
  3. need someone to double check the build list
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2011, 09:13 AM
  4. Help me build my Xmas list of parts lol
    By jteske88 in forum The Rant Forum
    Last Post: 07-16-2011, 10:49 AM
