Thread: Best 1.7 rockers for a VS cam
Results 1 to 17 of 17
Threaded View
  1. #4 Re: Best 1.7 rockers for a VS cam
    Apr 2011
    Elk Rapids, Michigan
    The only way to get more lift is to increase your rocker arm ratio to 1.7. That will increase the lift at the valve. You won't get any change in duration or LSA. Doing the math, there isn't a ratio that is available that comes close to the XP. The XP also has a much different lift profile than a VS. The VS has 0.005" more intake lift than exhaust lift where the XP has 0.016" more exhaust lift than intake lift. There's no way to get similar numbers by changing the rockers.
  1. rockers yay or nay?
    By asite57 in forum General Tech Discussion
    Last Post: 05-13-2012, 01:53 AM
