Thread: Fuel issue
Results 1 to 17 of 17
  1. #1 Fuel issue
    Aug 2012
    Cushing, OK
    ok guys so i went to my buddys house went inside and stayed the night there the next morning i went out and the car wouldn't start.. Fuel pump wouldn't come on so i bought a new fuel pump and put it in and the car fired right up and ran good for about 5 mins and then started cutting out and died. rechecked my lines and let it set for about 5 mins and then it did the same thing over again.. What happen??? the car has about an 1/8th tank could that be it?? and also could the fuel filter be plugged up again i changed it about a week before the fuel pump went out
  2. #2 Re: Please Please Please help!!!!!!
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    What are we looking at here? 97-03, 04+? Gt, GTP? Check the wiring for the pump. Are you parked on a hill and low on fuel?
    GPONA #1 Cyber Bully
  3. #3 Re: Please Please Please help!!!!!!
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Go get yourself a couple of gallons and try again
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: Please Please Please help!!!!!!
    Aug 2012
    Cushing, OK
    its a 99 grand prix ftp sorry about that.. and no I'm not on a hill and ok ill try that keep the ideas coming please it also has a code that says evap system pressure low or something like that
  5. #5 Re: Please Please Please help!!!!!!
    SE Level Member joelee669's Avatar
    Jan 2012
    manville, nj 08835
    deff check the harness to the fuel pump.. the pins inside of my connectors got loose witch make it hot then it gets worse.. have someone in the trunk just put a little pressure on the connector and turn the key and see if u can hear the fuel pump prime itself
  6. #6 Re: Please Please Please help!!!!!!
    Maybe the resistor?
  7. #7 Re: Please Please Please help!!!!!!
    Maybe the resistor?
    nope..resistor is start and stall, key off..start stall.. key off..start stall.
  8. #8 Re: Fuel issue
    Aug 2012
    Cushing, OK
    i bent the prong on the one relay because it kept starting and dieing. and could it be possible that its just not getting enough power??? or is it all or nothing?? because this new fuel pump seems to be really quiet. and like i said the fuel filter isn't but a week old and it is a little low on fuel please help guys i need this thing running
  9. #9 Re: Fuel issue
    Aug 2012
    Cushing, OK
    no one else have any thing?
  10. #10 Re: Fuel issue
    Aug 2012
    Cushing, OK
    i put more fuel in it and its running awesome now until it builds boost.. as soon as it starts building boost it falls on its face please help I'm lost guys
  11. #11 Re: Fuel issue
    SE Level Member cardiffGIANT98gtp's Avatar
    Kansas
    i'm having sort of the same issue. car started this morning and ran for about a minute. i can still here the pump but it doesn't sound normal. would that be the resistor or the pump?
  12. #12 Re: Fuel issue
    Aug 2012
    Cushing, OK
    i found that i had a vacuum line loose i put it back together and it attest doesn't cut out in neutral now when i punch it.. but when its under load and i give it much throttle at all it falls on its face... the vacuum line off the fpr had just a slight hint of gas smell but the fpr doesn't have any smell at all
  13. #13 Re: Fuel issue
    Nov 2009
    Central Jersey
    time for a new FPR
  14. #14 Re: Fuel issue
    Aug 2012
    Cushing, OK
    my for doesn't have a flu smell though i had a mechanic look at it and smell it and he said the fpr was still good i have a brand new fuel pump and I'm only getting 25 psi fuel pressure??
  15. #15 Re: Fuel issue
    Aug 2012
    Cushing, OK
    i also have the 85 pin of really #14 bent back and still only getting 25 psi even on the key on engine off prime
  16. #16 Re: Fuel issue
    Vacuum test the FPR.
    DOA fuel pumps doesn't surprise me. I warranty more than a few delphi pumps.
  17. #17 Re: Fuel issue
    Aug 2012
    Cushing, OK
    it was a precision pump and sure enough i went and got it warrantied and it runs like a dream now.. i also just received my over kill pcm and installed it..
