Thread: 04 fuel filter problems
Results 1 to 6 of 6
  1. #1 04 fuel filter problems
    gardner,mass
    So the other day i went to go pick up a fuel filter (easy task right?) Well after going to advanced they tell me they cant get it and then auto zone same thing. So i think it must be a dealer item even though that wouldnt make much sense. I go to the dealer and they tell me its 52 bucks. For a fuel filter? ya...no.... So i try one more store CAP. They tell me they have the part and its 13 bucks and it will be in next day. They order it i get it and pull off my old filter. Well after looking at them both the new one has 1 smaller tube and 1 bigger tube on the input side, and the old one has 2 of the same as the larger one. Does anyone know why? Did someone change this filter and fuel lines out befor? the vehicle has 90k on it. Or did i get the wrong filter and they are all retarded. Are you guys filters inputs the same size or one smaller than the other?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: 04 fuel filter problems
    Mahle W0133-1775444 Fuel Filter | Auto Parts Warehouse
    looks to be the same size on both sides.
    list of everything: http://www.partsgeek.com/catalog/200...el_filter.html
    wix looks like it might be the same on both sides as well.
    Which parts store did you go to?
    Try Napa and see if they have a fuel filter, they use WIX filters IIRC.
    the delco looks like the one you mentioned there as being incorrect, the mahle is cheaper than the delco yet appears to have the correct piece on both sides.
  3. #3 Re: 04 fuel filter problems
    gardner,mass
    oh nice thanks matt ya i went back to CAP and returned the filter they gave me and looked at the lable on the one under my car is appears to be 10237403 tennex 3410b
    edit oh no the 2 in that number must be a 3 cus looking as that mahle is the one under my car
    Thanks alot ****ing parts stores
  4. #4 Re: 04 fuel filter problems
    gardner,mass
    i called cap back they have the wix one so i had them order that for tomarrow and ill see if its the correct part and post back for people
  5. #5 Re: 04 fuel filter problems
    its not the parts stores fault the manufacturers catalog is incorrect.
  6. #6 Re: 04 fuel filter problems
    gardner,mass
    oic
  1. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  2. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
