Thread: Electrical Problems(Help needed)!!!!
Results 1 to 5 of 5
  1. #1 Electrical Problems(Help needed)!!!!
    SE Level Member Elusive85's Avatar
    Sep 2011
    Flint, Michigan, United States
    I noticed my car I very funny while it's hot. I got evap code boost solenoid, up stream O2 sensor, and MAF Low Circuit I replaced the MAF and I'm getting no voltage going to the MAF period. When it's put on the computer it shows no change in any of the readings. What do you guys think it is? Has anybody every had this problem?
    Elusive85
  2. #2 Re: Electrical Problems(Help needed)!!!!
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I notice when I very funny people laugh......and on that note lets get to the problem it is only when its hot? Ur Maf has no volts or all the time also have u tried unpluging sensors and see if u get maf voltage back or wiggling wires and when u say no volts are u checking with a scan tool or meter also what year would is it might be a bad sensor causing you to loose 5 volt ref from Pcm or could be Pcm all togeather
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
    Sep 2011
    The car is a 99 grand Prix gtp and yes I'm using and scan tool to check the readings and there is no power going to the maf at all. And I have unplugged the maf and still no voltage. I have checked all fuses and grounds. I have tapped on the maf and changed it twice fresh out the box. Any advice will be greatly appreciated.
    Elusive85
  4. #4 Re: Electrical Problems(Help needed)!!!!
    Start digging,
    As in find out why you have no power, start looking at the wire harness and pigtail for the maf.
  5. #5 Re: Electrical Problems(Help needed)!!!!
    Apr 2009
    Elkhart
    ya also use a meter and ohm out the wires to the ecm and maf and see what one is broken
  1. Electrical problems?
    By Max in forum General Tech Discussion
    Last Post: 03-23-2012, 03:03 AM
  2. Few Electrical Problems
    By str3etgl0w in forum General Tech Discussion
    Last Post: 08-29-2011, 11:59 PM
  3. PLEASE HELP ME! electrical problems
    By tomshaze in forum 04+ Specifics
    Last Post: 09-04-2010, 11:43 AM
  4. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  5. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
