Thread: p0171 cheched and replaced all vacuum lines need help!!!
Results 1 to 16 of 16
  1. #1 p0171 cheched and replaced all vacuum lines need help!!!
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    since i have swapped in my 97 gtp motor and trans into my 02 gt i have been getting a p0171 and p1133 dtc. i have replaced the upstream o2 sensor and replaced all vacuum lines. up until yesterday the codes were interminttent. now they are on 5 min. after resetting the SES light. any ideas anyone?
  2. #2 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Have a way to scan it?
    Are the fuel trims pegged at 16.4?
  3. #3 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    only at idle are they pegged at 16.4, with a little on the gas they go down
  4. #4 Re: p0171 cheched and replaced all vacuum lines need help!!!
    What programming was used in the PCM?
    P0171 being Lean Bank 1
    P1133 Being insufficient switching of the O2
    Insufficient switching is usually cause on startup by a bad heating circuit or lack of power to the heater circuit.
    Lean bank... well that's often a vacuum leak. I'd grab the TB cleaner and start spraying a round the TB, the bottom of the SC to LIM, where the injectors go into the lim. And I'd pull the EGR to LIM tube and look for the usual crack at the LIM end. Theh pull the battery cables back of the battery and clean the heck out of them if they are dirty. This is an area that is often overlooked. P0171 can be power/resistance related. I've had to swap battery cables to cure it before.
  5. #5 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Did you change gaskets out when you swapped the supercharged motor in?
    Or did you just "trust em"?
  6. #6 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    trusted them didnt see a need to change them i did the valve covers. i was looking at the egr tube into the exhaust manifold and the bolt had fallen out but no exhuast was leaking so i figured it would be fine. im going to replace the bolt and clean the battery terminals
  7. #7 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Probably needs LIM gaskets.
    Wanna bet?
  8. #8 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Since the bolt is out.. that's the issue. However...pull that tube and look at the end where it meets the LIM. 90% of the ones I see have a hairline or worse crack at the point that the piece holds it to the LIM. That will also screw with you.
  9. #9 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    i was looking at the intake under the TBand im having some some coolant pool up on the block but im not buring any in the motor and there isnt any in the coolant
  10. #10 Re: p0171 cheched and replaced all vacuum lines need help!!!
    There isn't coolant in the coolant?
    Huh.
    Delete the EGR...change the LIM gaskets. If there is coolant leaking out somewhere, something is failing.
  11. #11 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    how do i delete the egr with no codes getting thrown i dont have a tuner or any way of removing the codez
  12. #12 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Who cares its just the EGR codes...you use two pennies and some RTV, cut off the brackets from the metal tubes, and bolt the brackets back down to the manifold/LIM after the pennies and RTV have dried.
    Buy a tuned PCM from reptile.
    Be done.
  13. #13 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    deleting it without removing the codes isnt an option need to pass emissions inspection. i have a crap canned tune from zzp and am looking to buy a tuner used or new im going to try the free thing first to see if it remedys the problem
  14. #14 Re: p0171 cheched and replaced all vacuum lines need help!!!
    I'm a fan of simply fixing the EGR with a bolt and checking the tube. No codes, no issues, no extra work. You are stock enough that there is no value in you deleting it.
    As for the coolant. Is it leaking from the cover on the LIM right below the EGR tube or above? You sure it's not leftovers from the bleeder valve when you bled the system?
  15. #15 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    ill soak it up with a rag and check the tube while in there.
  16. #16 Re: p0171 cheched and replaced all vacuum lines need help!!!
    Sep 2012
    bridgeport,NY
    its the gaskets which ones should i use the rubber or metal ones
  1. Vacuum Lines on gen 3
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-05-2012, 10:20 AM
  2. Vacuum Lines and what not
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2012, 04:20 PM
  3. vacuum lines
    By shawn3091 in forum General Tech Discussion
    Last Post: 01-11-2010, 10:15 AM
  4. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
