Thread: engine swap
Results 1 to 4 of 4
  1. #1 engine swap
    Sep 2012
    hey there, i bought a 99 g.prix gtp 2 years ago, one owner, low km's, minty condition, beautiful over the last year or so i've put about 4k into it and got the beaut back to perfection.
    2 days later, something with a piston goes, not sure, but a mechanic said not worth to fix it, i say bs, she's not going out like that.
    so i found an engine locally for sale, 100,000km's newer and also from a 03 g.prix gtp, so 4 years newer too, only $750
    and can swap it my self with my grandfather, so thats no problem
    i just need to know if the swap would work, so i have a 99 and want to swap with an 03 both 3.8L supercharged
    any input would be appreciated
  2. #2 Re: engine swap
    Everything is a direct swap.
    Use your 99 wire harness and PCM.
  3. #3 Re: engine swap
    Unhook motor from harness and transmission, lift out. Drop new in and smile.
    It's a direct drop in.
  4. #4 Re: engine swap
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    dont not attempt to use the transmission. gm changed the trans wiring in the case in 2003 wikipedia should help with this i would link but dont know how i say reuse your 99 trans. with your 03 motor
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Engine swap 01 gtp into 00 gt
    By jpimp in forum General Tech Discussion
    Last Post: 11-17-2011, 01:40 AM
  3. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. 99 GT Engine Swap
    By EarlyGTDriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-19-2009, 01:40 PM
